Question about HP COMPAQ T5530 800MHZ CE (RK270AA#ABA) Network Terminal
T5530 USB device not recognised. Not able to flash BIOS. Please help to have the correct BIOS utility. Thanks
    Guru:
  • 558 Answers
Have you check by Tapping F2, DEL or ESC key during bootup?
Try to connect other devices such as mobile, printer with USB.
Let me know the result.
Regards
Ellin
Posted on Sep 26, 2008
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
I want upgrade bios ga 8simlh rev 1.0,but can not
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
How to update asusp5gc-mx bios by usb
Well if you have two optical drives, it's easy. You can simply download the FreeDOS LiveCD (base image) from http://www.ibiblio.org/pub/micro/pc-...0/fdbasecd.iso and burn that to a CD. You can then burn the BIOS flashing utility and the BIOS image from your motherboard website to another disc, boot up your box, change to the second drive, and run the utility
But what if you don't have two optical drives? Or what if you don't have ANY optical drives? I found myself in this situation recently. I was working on an appliance that had only a compact flash (CF) boot slot, and a few USB ports. It lacked not only an optical drive but also a hard drive, and I needed to flash the BIOS to current.
I did the usual Googling and found lots of outdated articles, none of which adequately explained how to make a USB key boot DOS, although I did piece together enough clues to figure it out with some experimentation.
You'll need a few things to make a DOS bootable USB thumbdrive with these instructions:
The HP Flash Drive Format Utility (via the PC World Website):
http://www.pcworld.com/downloads/fil...scription.html
The FreeDOS 1.0 base image ISO:
The WinImage Utility:
http://america.winimage.com/download/winima80.exe
Steps to make your fancy, schmancy DOS booting USB drive:
1.Download and install the HP USB Disk Storage Format Tool and WinImage
2.Make a directory on your desktop called “DOSBootDisk”
3.Start WinImage and open the fdbasecd.iso file, you will see a directory structure
a.Select Image > Extract and browse to your DOSBootDisk directory
b.Check the “Extract all files into the same folder” and click “OK”
c.When it prompts you if you want to overwrite duplicates, say Yes
d.You can now exit WinImage, you won't need it again
4.Connect your USB flash drive to your machine and backup any files you want to keep (as it will be completely erased in this process)
5.Start the HP Flash Format utility
a.In the first dropdown box, select your flash drive (mine displays as a Corsair 2GB flash drive). Be careful that you have the correct drive as this process will erase your device.
b.Set the File System to FAT
c.If you want, give your system a volume label, for example “BOOTDISK”
d.Check the “Create a DOS startup disk” box
e.Select “Using DOS system files located at:” and browse to your desktop and select your DOSBootDisk you created in step 2.
f.Click Start and say Yes when it warns you about formatting your device
g.Watch the pretty status bar progress
h.Click “Close” when it is done
6.Now open your formatted USB key in Windows Explorer and copy your BIOS flash utility and your BIOS image to your key so they are available once you reboot. Feel free to throw in any other DOS utilities you want... I can't think of any but since you're here you obviously know something about DOS...
7.Shut down Windows XP, reboot your machine, ensure your BIOS is set to support booting from a USB device (this varies by BIOS, ensure both the option is enabled and your USB device is in your boot order about your hard drive and optical drive). Save your changes and exit.
8.You should see your machine boot FreeDOS 1.0 from your USB key.
9.Run the BIOS upgrade utilities you copied to the disk earlier.
Dec 16, 2009 | ASUS P5GC-MX/1333 Motherboard
I want the bios recognise usb flash
Start Windows.
Insert the USB flash-memory device.
Windows should recognize the device, and assign a "drive-letter", such as 'E:' or 'F:'.
Open "My Computer".
Select the 'E:' or 'F:' drive, and browse the files/folders.
Nov 14, 2009 | Fujitsu AMILO D-7820 Notebook
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Usb device not recognised.
install the driver for it
search it from
download.com
"can u please rate me free.... for my hint"
thanks in advance
May 17, 2009 | Transcend (589307) Media
Usb port not recognising devices and mouse pad not responding
hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Nov 23, 2008 | Microsoft Computers & Internet
Usb ports
u can upgrade the bios in your pc by downloading the bios from the manufacturers site ,i thinkthat shld get it to work with the usb device
Jul 16, 2008 | Computers & Internet
XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Mar 30, 2008 | Electronics - Others
USB port problems
Try going into the BIOS and see if the USB Ports are enabled. I don't know what type of system you have. When you turn on the pc it will prompt 'F1 to enter setup' or it might be F10. Do you have a USB mouse or keyboard? Try those in different ports.
Jun 12, 2007 | ASUS EXTERNAL USB FLOPPY DRIVE (ASUUSBFDD)...
HP COMPAQ T5530 800MHZ CE (RK270AA#ABA) Network Terminal Logo
212 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
