Question about Hitachi Televison & Video
Can not change channels on TV
Recently I can not change the TV channels on the LCD rear projection tv. I tried the channel switch on remote and on the TV and they does not work. I do not know if it is possible to reset the TV or how to fix this issue.
  • mikema_usa Sep 26, 2008
    I tried unplug the power from the wall for 5 min then plug back in, the TV channel bottons still do not work. only volume botton and power on and off botton work. I could not figure out why.
    Thanks.
    Mike
I have the original remote and tried what you suggested. The problem is that the bottons on both remote and tv pannel do not work except the power and volume bottons. I called the hitachi service center today and they have not met this problem.
Thanks.
Mike
Posted on Sep 27, 2008
  • 927 Answers
Good Day;
To reset the TV unplug power cord from the wall for 2 to 5 minutes then plug back in.
Good Luck, big IRISH.
Posted on Sep 26, 2008
  • MICHAEL MULLINS Sep 27, 2008
    Good Day;
    You have an universal remote!!! Try pushing the button of the device that you want to operate; EG you want to control cable box to change channels push "CBL" button then change channels, push dvd button then remote will operate the dvd.
    Thanks for additional info, big IRISH.
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
I'm using LCD tv tuner box , to switch on TV mode in My LCD Monitor ,Since recently not able to change the channel it's displaying one channel only.
I think perhaps we have a language barrier here as I really to be honest do not see what your question is?
Dec 11, 2012 | Televison & Video
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
Change the aspect ratio
you can set the aspect on either remote. the best thing to do is set the proper aspect on the tv remote for regular (sd) channels, and then again for hd channels. the tv should remember these aspect settings and revert to them when you switch back and forth from sd to hd. if you have satelite, there is usually another aspect on there you can change depending on the program, but i usually recommend leaving it alone. if you are on an hd channel with side bars, switch to the sd version instead of changing aspect so you dont have to keep flipping it back and forth.
May 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
Cannot change channel to a 2 digit channel eg.
some remotes used to have a key to switch between single or double digits marked ( -/--)
Oct 27, 2009 | Samsung TV Remote Control
No picture cant use remote to turn tv on/off or change station.
Hi,If I am understanding the remote control is not turning tv right? here's the one you need http://www.newtvremotes.com/Mfrs/Hitachi/HitachiTV/CLU-3842WL.htm God bless you.
Oct 02, 2009 | Hitachi Televison & Video
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem with PIP Function
To turn off PIP. Use tv menu and auto set channels, once searching for channels, turn off and PIP will be gone. If you can't access auto program tune tv to channel 3 and try again.
Nov 24, 2007 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
193 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
