Sylvania G-Netbook Logo
Anonymous Posted on Nov 07, 2011
I NEED TO FIND MY IP ADDRESS - Sylvania G-Netbook
Anonymous
Level 3:
  • Master 408 Answers
  • Posted on Nov 07, 2011
Anonymous
Master
Level 3:
Answers
408
Questions
Helped
90480
Points
1171
Nicole, enter this link on your browser and it will give you your IP address:
http://www.lawrencegoetz.com/programs/ipinfo/
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA!Bestregards,
Junior
1helpful
Can't find IP address 192.168.1.2
Your IP address 192.168.1.2 is a Local IP address. Local(Computer) IP address ranges from 10.0.0.0 to 10.255.255.255, 172.16.0.0 to 172.31.255.255, 192.168.0.0 to 192.168.255.255. Normally you can login the Local IP address within a single building (or) campus using LAN. If you need to access around the world, it should be a Public(Network) IP address. To check your Network IP address, visit IP-details.com .
1helpful
4answers
How to find a IP address for my emachines laptop
go to start -- run and type in CMD
hit enter to open a black command prompt window
type in "ipconfig" without the quotes and hit enter. This will give you your IP address.
If you need the IP address from your provider that you are using out on the public internet, just go to http://whatismyipaddress.com/ and it will tell you what your external public IP address is.
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
Need ip address
You need to check the Ip-address?Or you need Ip-address,You need ip-address means call the service provider and get it,You need to check the ip-address means visit the site Ip-details.com
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
2helpful
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
2answers
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
4helpful
About n/w printer
If you have the network enabled 1022 you need to find out it's current IP address. To do this press & hold the Go button on the top of the printer (the large button) for 5 - 10 seconds or until the printer starts to print. This prints out the configuration page.
The printer is set to get an IP address via DHCP from the factory, but once you have it's IP address you need to give it a static IP address. You can do this by typing the IP address into a web browser & go to the network tab. choose an IP address that has not been allocated already & apply the changes.
You will need to type the new IP address into the browser if you want access to change further settings.
You can then add the printer using the new static IP address.
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Top Sylvania Computers & Internet Experts
Paul Bade
ADMIN Eric
ADMIN Eric
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
