Not getting power fuses r good - Televison & Video
  • 927 Answers
Good Day;
Sounds like you have circuitry problems. I would recommend that you call an Authorized Service Center and come out and give an estimate. Without Model or Brand I'm sorry I could be more precise.
Good Luck, big IRISH.
Posted on Sep 26, 2008
  • charlesrolls Nov 05, 2010
    This problem occured with model P52936,any Ideas.
Having a no crank issue in my 1990 toyota 4x4 3.0 engine. No power at AM1 fuse. Fuse is good. Starter relay checked and it clicks. Headlights work. No dash lights. Replaced ignition switch. Still won't...
Check the harness bulkhead connector at the firewall. If you have been driving in deep water, you will get corrosion here. This connector is where power enters the cab (kickpanel fuse block). Use conductive grease at connector after cleaning the pins
Aug 18, 2017 | Toyota Cars & Trucks
Obd port no power, ltr fuse under hood is good, no blown fuses
8b7039ac-88a4-4bf8-9225-c835a0bb02a3.gifto be sure test terminal 16 with test light to a good ground
test terminal 4 and 5 with test light to good power
if all good check for terminal wide open to much
if power is not good underhood block fuses turn over check connector c2 d9 for power if good wire cut ckt 640
Oct 10, 2013 | 2007 Chevrolet Silverado 2500HD
No power to windows, radio, dash
I would start by checking if the under dash fuse panel is getting power to all the fuses. A few will be hot at all times (like the brake light fuse, horn fuse), but with key on, all fuses in the fuse panel should have power available to them.
Use a test light, clip the ground clip to a metal bracket, and use the test light probe to touch the fuses at the ends-the little indents on top of fuse is open to the metal strip in the fuse. When the probe touches that strip, the test light should light, meaning power is getting to the fuses. No light? Maybe not grounded good-keep trying until you get a light when touching the fuses through that little **** at top of fuse. When you have a good ground, check all fuses. With key on, all fuses should have power-now you can check the radio fuse and dash fuse.
You can do this also to check for a blown fuse. Even a blown fuse will light the tester on one end of fuse. A good fuse will light tester on both ends of fuse. A blown fuse will only light tester on one end. You can check fuses this way without pulling the fuse out to inspect.
If no power to the fuse panel or to part of the panel, look for a bad fusible link or maxi fuse that distributes power to the fuse panel. There may also be a relay (ignition relay) that the key switch turns on to send power to the fuses that are hot in accessory or run.
Sep 30, 2013 | 2001 Toyota Celica
Installed new blower motor. bearing shelled in old one. new motor won't blow. tested . it's good don't have power to moter. fuses good relay good. isthere a circuit breaker in wiring for b
I don't have a diagram for a 2008. On 2005 models the blower motor relay gets power from a 30amp fuse.
When the blower switch is in the high position the resistor is bypassed and power flows directly to the motor. The motor is grounded to the car.
The fan relay also gets power from a 7.5amp fuse and is controlled by the HVAC control on the dash.
Do you have power into and out of the relay?
Feb 25, 2013 | 2008 Mitsubishi Lancer
Need a diagram of fuse panel on 91 buick park avenue for heater fan
GET A GOOD FUSE TESTER TURN ON IGNITION SWITCH. TEST EVERY FUSE. 2 FUSEBOXES ONE UNDER THE HOOD, ONE INSIDE THE CAR. FUSES CAN BE TESTED WHILE IN THE BOX. FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE, POWER ON BOTH SIDES, GOOD FUSE POWER ON NEITHER SIDE, SPARE FUSE.
Jan 13, 2011 | 1991 Buick Park Avenue
I can't get my dome light to work. Witch fuse is associated with this problem? where can i get a fuse box diagram?
GET A GOOD FUSE TESTER, TEST ALL OFF THE FUSES. THERE ARE 2 FUSEBOXES, ON UNDER THE HOOD & ONE INSIDE THE VEHICLE. ALL FUSES CAN BE CHECKED WHILE STILL IN PLACE . THERE ARE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE. POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE, SPARE FUSE.
Jan 10, 2011 | Ford Ranger Cars & Trucks
My windows and drivers seat aren't working. what can I do?
GET A GOOD FUSE TESTER, CHECK EVERY FUSE. 2 FUSE BOXES, ONE UNDER THE HOOD, ONE INSIDE THE VEHICLE. ALL FUSES CAN BE TESTED WHILE STILL IN THE BOX. THERE ARE TEST POINTS FACING OUT. POWER ON ONE SIDE ONLY, BAD FUSE POWER ON BOTH SIDES, GOOD FUSE POWER ON NEITHER SIDE, SPARE FUSE.
Jan 06, 2011 | 1999 Toyota Camry
Location of the turning signal fuse
GET A GOOD FUSE TESTER, TEST EVERY FUSE. 2 BOXES ONE UNDER THE HOOD & ONE INSIDE THE VEHICLE. THE FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE POWER ON BOTH SIDES GOOD FUSE, POWER ON NEITHER SIDE, SPARE FUSE.IF THE FUSES TEST OK, YOU MAY HAVE A BAD FLASHER, OR BAD TURN SIGNAL { COMBINATION } SWITCH.
Jan 06, 2011 | Daewoo Lanos Cars & Trucks
No rear signals or brakelights except third brakelight
TURN ON IGNITION SWITCH,GET A GOOD FUSE TESTER, CHECK ALL FUSES INSIDE THE CAR & UNDER THE HOOD. THE FUSES CAN ALL BE CHECKED WHILE STILL IN THE FUSE BOXES THERE ARE TEST POINTS FACING OUT ON EACH FUSE. POWER ON ONE SIDE OF THE FUSE, BAD FUSE. POWER ON BOTH SIDES, GOOD FUSE. NO POWER ON EITHER SIDE , SPARE FUSE.
Jan 05, 2011 | Dodge Pickup Cars & Trucks
Interior dash lights, signal lights and 4 way flashers don't work.
Jan 05, 2011 | Toyota Tacoma Cars & Trucks
Open Questions:
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
