Question about Samsung SyncMaster 245BW Monitor
Extenced Display Identification Data from Monitor's DVI Port is Incorrect
My new SyncMaster 245BW display maxes out at 1280x1024 @ 75Hz when it should be set to 1920x1200. I bought it refurbished, so I have no recourse to Samsung. Also, I would much rather just flash the monitor with the correct EDID data than go through the hassle of sending the monitor back and having to shop for another one, or exchange for another refurb with the same problem. (I suspect the first buyer sent it back because of the resolution issue.)
Anyway, I have a software tool called PowerStrip that can handle the flashing part. I just need to know how to turn off the write protection on the eepron chip. It would be icing on the cake if I could get the correct edid data in hexadecimal format, so I could just flash it in. However, I will settle for getting the right values so I can make the hex file myself. Any help will be much appreciated. I will include the errant edid values below for reference. Also worth mentioning, I have an ATI Radeon X800 video card, so more than sufficient to drive the display at full resolution,
Registry Key : DISPLAY\SAM0161\5&1ae31e66&0&10000084&01&00
Monitor Name : SyncMaster
Manufacture Week : 20 / 2004
ManufacturerID : 11596 (0x2D4C)
ProductID : 353 (0x0161)
Serial Number (Numeric) : 0 (0x00000000)
EDID Version : 1.3
Display Gamma : 2.20
Vertical Frequency : 56 - 75 Hz
Horizontal Frequency : 30 - 81 KHz
Image Size : 33.8 X 27.0 cm (17.0 Inch)
Maximum Image Size : 34 X 27 cm (17.1 Inch)
Maximum Resolution : 1280 X 1024
Support Standby Mode : No
Support Suspend Mode : No
Support Low-Power Mode : Yes
Support Default GTF : No
Digital : Yes
Supported Display Modes :
720 X 400 70 Hz
640 X 480 60 Hz
640 X 480 67 Hz
640 X 480 72 Hz
640 X 480 75 Hz
800 X 600 56 Hz
800 X 600 60 Hz
800 X 600 72 Hz
800 X 600 75 Hz
832 X 624 75 Hz
1024 X 768 60 Hz
1024 X 768 70 Hz
1024 X 768 75 Hz
1280 X 1024 75 Hz
1280 X 1024 60 Hz
  • Anonymous Oct 16, 2008
    Exactly the same issue.  I had a 245BW whose backlight went out.  Samsung shipped an advance replacement (after 1 full month!!!).  This replacement monitor shows a max resolution of 1280x1024 in PowerStrip.  I can set it to 1900x1200 in the OS but it still just displays 1280x1024 of it at a time and makes me scroll around.
  • sfjstars Mar 20, 2009
    I have the same problem. I just got the monitor and foudn it was refurbished. I am using it with a dell Laptop in an extended display configuration. When I set it to the 1920 x 1200 resolution the monitor stays in 1280 x 1024 mode and just let's me scroll around on the screen.
Riziel
  • 116 Answers
SOURCE: syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Posted on Nov 26, 2007
fossilruins
  • 114 Answers
SOURCE: New Samsung 245/bw monitor w/native resolution of 1920x1200
Ensure that your video setting is at 60hz when at 1920x1200. According to the specs of your monitor, the freq from the video card might be set to something higher.
Posted on Jun 08, 2008
skotkolr
  • 558 Answers
SOURCE: Monitor will not display in native resolution.
sounds to me like they replaced your vga board with another compatible one but not the same exact one I would call the repair facility that did the work and ask questions about how they repaired the monitor like if they used another vga board etc. hope this helps
Posted on Jun 19, 2008
hmerchant110
  • 7191 Answers
SOURCE: Samsung Syncmaster 551V Display is too wide
You can adjust the monitor picture size settings & position from the menu button on your monitor.
Posted on Apr 23, 2009
Kuwagata
  • 181 Answers
SOURCE: My syncmaster 245 bw will only display a blank
You need to adjust the monitor refresh rate to 60 Hertz or 70 Hertz.
Use the CRT first to adjust it, then after adjust,plug in your Sync Master to see is it perfect or not,find the best frequency that work best.
To adjust it,right click on the screen,enter properties, then click setting tab.
Then in advanced tab, click it then you see the monitor tab, find the perfect screen refresh rate.
Posted on Dec 10, 2009
Samsung 245BW No Display
have you tried this monitor on another computer? what was the result? Also, try laying the monitor down flat and see if you see any "ghosting" from the characters on the screen. (if the backlight goes out on the monitor, you should be able to see some of the graphics displayed on the screen still with a flashlight or at an angle if the monitor is working)
let me know what you find out
Jun 09, 2012 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
My syncmaster 245 bw will only display a blank screen through the dvi port. Another crt monitor works fine through the vga port . I'm running a nVidia 7800 GS video card.
Dec 10, 2009 | Samsung SyncMaster 245BW Monitor
Jun 19, 2008 | Samsung SyncMaster 245BW Monitor
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
245BW monitor not working (stranges colors ad aeternam...)
I had the same problems as almost all of these people and the answer seems to be that I uninstall the current Nvidia Drivers and use a previous set. The 169.28 were a real problem for me. Just when I thought it was working I would get the strange wash out and I could not turn it off except with the back power switch, aslo using the DVI turns off all the on screen controls.
Good Luck
Dec 27, 2007 | Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 245BW, can't get it up and running !
Most of the time when this happens it is due to a bad monitor, if you have another pc try to hook this monitor up to that one to see if it actually works, these monitors sometimes get damaged during shipment!
Jul 25, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW Monitor Logo
133 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
