Question about HP Photosmart D7360 All-In-One InkJet Printer
Paper Jam there is a sheet of paper stuck up where it gets ink on it i think how do i fix that? help ASAP please thanks
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Sep 26, 2008
I put paper on my hp printer and keeps jaming up wht can i do to fix tht problem thank you get to asap thanks again
60 Second printer paper jam fix by hp technician solves feed ...
? 4:56
www.youtube.com/watch?v=BdFvyDZmiFI
Oct 25, 2011 - Uploaded by BrokenPrinter1
60 Second paper jam fix by hp technician how to solve feed ...I've been trying to figure out why my printer has been jammingfor days! Days I ...
Fixing a Paper Jam - HP Deskjet 3050 All-in-One Printer ...
? 12:07
www.youtube.com/watch?v=suiQgoH-8cM
Jul 5, 2011 - Uploaded by HP Printer Support
My hp printer was working great until yesterday when I seemed to be taking ... I was able to fix the paper jam error on my friend'shp desktjet ink ..
Oct 20, 2015 | HP Office Equipment & Supplies
Please help me with printer jam
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you get toner or ink on your clothing, wipe it off with a dry cloth and then launder the clothing in cold water.
Watch out for loose toner or ink on jammed paper, and do your best to avoid spilling it on yourself or the printer. If a little bit of loose toner or ink gets in the printer, though, it should clear after a few sheets are printed.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
Printer is saying paper jam and I have cleared out all paper and clippings that were stuck how can I get it to stop saying paper jam?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink. Even if its not finished. They give you extra. And clear out all the paper from the cutter traay before you move the printer.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Oct 19, 2010 | Sony SnapLab UP-CR10L Digital Photo...
False Paper Jam Message
Probably a jam sensor is dirty or stuck. Look through the paper path for a stuck plastic sensor arm, or dirt or paper dust on photocell typr sensors.Paper sensors are normally located near where paper feeds, and where it exits the machine. The paper must pass over these sensors as it travels through the machine.If a scrap of paper is left on the sensors, they will report it as a jam. If you can, try manually pushing a sheet of paper through the printer, ONLY in the direction it normally feeds. This may free up a stuck sensor arm, or force out the jammed scrap.
Jun 08, 2008 | Brother MFC 420CN All-In-One InkJet...
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
Paper jam
Remove the back cover and look if there's any paper stuck in the feeding mechanism.
Feb 15, 2008 | HP DeskJet 6122 InkJet Printer
Problem
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
Regards
Malik Khan
Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
Paper jam error, no paper to be found
Hi there I had one of these back at the workshop with the same problem it turned out to be a drawing pin that had stuck down the paper path. When you ope all the covers does the jam go away? If not there maybe a torn piece stuck in there. I don't think the two are related but worth a try to change ink. The other thing is that on some canon products you will have to press the stop button the clear.
Try this hope it works if not please get back to me.
J
Dec 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
Paper Jam Message
Where is it saying the paper jam is located? Do you have a service code? It sounds as if either a paper pass switch is stuck in the down position (meaning it thinks there's a piece of paper there), or you may have a sheet of paper stuck in the fuser or behind a guide plate. Check on these and let me know!
Apr 10, 2007 | Sharp AL-1655CS Laser Printer
HP Photosmart D7360 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
