Question about Samsung Televison & Video
Samsung HL-P6163W color wheel won't power up, so TV won't come on.
Recently replaced color wheel (original was noisy), TV came on, except that colors were reversed. Removed a jumper and then colors were fine. TV worked ok for several days, then stopped turning on. Looked inside back, saw no lamp light. Figured I jarred the lamp (was original one). Bought a new Phillips E23 lamp from discount-merchant.com, installed it, but no change. Looked closely at all connections I had touched, all appeared ok. Ordered and replaced ballast from samsungparts.com. No change. Pulled lamp back out, rigged case switch to stay closed, watched color wheel with mirror, and saw it was not turning on startup attempt. Figured maybe I screwed up the install, so I pulled it back out. Found everything ok, but wheel kinda stiff, hard to turn, maybe even slightly harder to turn than original. Also noticed it squeaks in a couple of places while turning manually. I never felt it before it was originally installed, so I wouldn't contaminate it, so I have no reference. Is this normal? Or, is my new color wheel bad? If it is normal, how do I figure out what is not powering up the color wheel? Any ideas for a next step?
    Top Expert:
  • Samsung Master
  • 74,459 Answers
Replace the color wheel. It is irreparable.
Posted on Mar 04, 2017
ctf1800
  • 4402 Answers
SOURCE: Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Posted on Jan 18, 2008
  • 29 Answers
SOURCE: Samsung blinking lamp light - nothng else
Check the ribbon cable coming from the color wheel, if you plug it in backwards it will do this.
Posted on Mar 15, 2008
SOURCE: lg 52sx4d won't turn on
Need to bring it to services to check to find out the reason. The nearest service. Hope it can satisfy you.
Posted on Sep 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung DLP HL-R5667W lamp won't fire. Changed
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Posted on Nov 27, 2009
  • 8909 Answers
SOURCE: bought my hitachi 50vs69a tv 3 years ago. put new
Take the lamp out and examine it. Are there any blackened markes that look like arcing marks? If there are then the lamp may be faulty and that could be caused by the ballast but in my experience of working with Sany and Philips lamps, the ballast units generally fail without causing lamp problems.
I should go for a new lamp.
Hope that helps.
Posted on Nov 04, 2010
Heard a pop sound, lost color, now i get loud buzzing no picture lamp light flashing and it turns itself off and on
Color wheel need to be replaced, required color wheel is available in Samsung Parts, click the link to view image and price info.
Thanks.
Jun 25, 2011 | Samsung HL-P6163W 61" TV
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
There is a whining sound upon powering up my HL-P6163W which softens after about 5 minutes, but doesn't disappear completely. I think the source is either the color wheel or the cooling fan. How can I...
It the Colors wheel,cooling fan will shut down,if it start making noise to the fan,because the whole projection egine and the bulb link to it.The fan have to run a certain RPM to keep the tv running without problems.These colors wheels run 1000 RPM to start to give the tv colors and it make out Flexy glass and plastics.What ur opinion,who will give u the problems,first as parts wise.Ok any noises like whinning in the tv alway the colors wheel starting to buckle and warp.Getting worse make motor noises and briddles enough will brake and shatter it into ten of hundred of pieces.Who know,than inside what else will cause the rythum of the RMPS running of the tv,when u replaced it.
Jul 31, 2010 | Samsung HL-P6163W 61" TV
Do i have to reset tv after changing color wheellamp and ballast.
No, but if you can update firmware, it would be recommended. Were the parts original manufactured...matching the monitor (TV)? No details on make/model.
Jun 29, 2010 | Samsung HL-P6163W 61" TV
I have a HL-P6163W, hooked to dish network hd
Fire the TV Tech! Your problem is the adjustment to the color wheel timing. To correct this: With TV OFF -> on remote, press MUTE, 1, 8, 2, POWER. The TV will come up in service mode: ( Left / Right arrow keys for item selection, Up / Down to change values, Menu to return to previous menu, Power to exit Service Mode)
Enter the submenu of item 1. DDP1011. Now, adjust item 4. INDEX DELAY to correct the "clay facing" problem you are having . Default value is 47.
You should have a "problem" image paused to check you work if possible. I hope this was of some assistance, best wishes.
Apr 12, 2010 | Samsung HL-P6163W 61" TV
Replaced color wheel on my Samsung 61" HL-P6163W. Colors on the TV are off. How do I reset this? I've seen posts regarding a jumper wire. Does this apply to my model? If so, where is this jumper wire?...
did u not pull the jumper if u put in a new air bearing color wheel it spins much faster u have too pull the jumper on the board beside the little fan its black just pull straight out its black little plastic thing look on the silver slotted case youll see two little square opening one has the black jumper right there pull it out did mine already see ya
Dec 29, 2009 | Samsung HL-P6163W 61" TV
How to replace faulty lamp cooling fan on HL-P6163W TV
A more likely candidate is the color wheel,unless your sure it's the fan
Dec 01, 2009 | Samsung HL-P6163W 61" TV
I need instructions on installing a color wheel
i found a step by step video on you tube it was great
May 05, 2009 | Samsung HL-P6163W 61" TV
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Televison & Video Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
