Dead set tv,power supply is good but no output voltage going to HVPS.no sound and picture.
  • Mike Hunke Sep 27, 2008
    the fuse was blown and the 2.7 ohm power resistor was open. I replace both and the fuse blows again. The power supply seams strange to me. The unregulated supply is rectified then it goes to a transformer to the regulated supply. How can you step down DC using a transformer. A schematic would be helpful.
  • 790 Answers
Hi
is there power in unregulated power supply? if have a power what is voltages? did you check the regulated power supply? or in the Hot area?
Likha!
Posted on Sep 26, 2008
Bravia kdl-40s4100 has no sound, no picture. Checked the line fuse to the HV power supply and it checked good. PS problem? Where can I find a replacement circuit board or would I be better off replacing...
The 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards are dead,must be replaced.These 2 long LCD inverter boards help the LCD screen to have a backlight to have a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jul 14, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
No power to kv-27fs120. suggestions on repair
Is it completly dead or do you hear a click (internal to TV)?
If completely dead - check main ac fuse.
Otherwise here are some tips:
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model (forSony -bad solders on horizontal drive transformer/regulators short)– for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Oct 30, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
JVC AV-32220 TV WAS WORKING FINE....NOW NO PICTURE OR SOUND BY
Power supply capacitor is usually suspected.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
Oct 17, 2009 | JVC AV-32220 TV
TV does not power on. Shows no signs of "turning over"
Can you measure the voltage at the AC power cord input? (110VAC) Usually yo at least hear arelay click or the set try to start and the go to shut down
I would start by measuring for ac and then see if you have any regulated DC supplies
Sep 28, 2009 | Mitsubishi VS-70707 70" Rear Projection...
No picture/sound
It is not likely your picture tube especially if the picture was good b4 it went dead.
Sep 27, 2009 | Sanyo DS31520 31" TV
My Projection TV (P46732BA) is dead ..Power is not on by remote or even using On/Off button ....Please tell Me why? What should I do ? dump it or fix it ....(My children are crying for their games) Thanks...
A very common fault with this TV is the HV block aprox $250-300 for repair shop repair. If the picture was good b4 it went dead it's probably worth repair.
Sep 27, 2009 | Televison & Video
Toshiba tv - power on - black screen and power light blinking -
Sep 27, 2009 | Toshiba 36AX60 36" TV
RCA 35V432T Dead Set
Check for a high voltage power supply section of your TV set...
Especially in flyback transformer.Be careful to do so because the output voltage of the flyback transformer is almost thousand volts.
Oct 17, 2007 | RCA 35V432T 35" TV
Dead unit
your problem is that your output is less than normal
first you isolate h/output from power supply if it comes to normal(115V).
then problem in h/output stage
for that you check
h/output,cap & diode in flyback section & flyback transformer.
but power output is still 50v then problem in power supply for that check oscillator ckt & switching output.
good luck.
Oct 17, 2007 | Philips 27PT543S 27" TV
TV started popping then died
sounds like the sound amplifyer IC in the set went bad and it holding down or blew out the voltage regulator. If your a tech first thing I would do is find the sound output IC and disconnect the main b+ lead and see if the tv will come on. if it did I would replace the audio output IC. If it didnt i would have to troubleshoot the Power supply for the missing voltage. if your not a tech its not advised to try to do this repair as there are no user serviceable parts inside this set. Seek A Pro to assist in this repair as there is hi voltage in this set even when its unplugged. Good Luck
Jun 11, 2006 | RCA P56950 56" Rear Projection Television
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
