Question about Whirlpool Washing Machines
My washer will stop after some time. water does not drain. whirlpool (ultimare care II) MOD : LSQ8543JQ1 SER : CL 0509810 TYPE: 111
  • Anonymous Mar 22, 2014
    MOD WFW 9050XW00
    Ser # HL03301086
    Type 832-A
    Sergeant:
  • 409 Answers
are there any error codes that come up on the display?
Posted on Sep 26, 2008
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Washer Won't Agitate
It might be the agitator dogs. Try to replace those
Feb 06, 2009 | Whirlpool LSQ8543J
Whirlpool Ultimate Care II spins only once in a while :-)
hi there,
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wobbly agitator
If you remove the center cap from the agitator there should be either a bolt or a square recessed socket that you can attempt to tighten. The bolt is either 7/16" or 1/2". The recessed socket can be tightened using a 3/8" to 1/2" socket adapter.
Make sure the agitator is seated properly on the center post. You can accomplish this by finding the mounting bolt and loosening it enough to free the agitator on the post and push down evenly on the bottom flanges at the base of the agitator where it meets to bottom of the tub.
Try this and let me know if it helps. Post back if you need further assistance.
Feb 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Won't Work
I not sure but sounds like u have a 2 piece agitator... sounds like gears in top of agitator is stripped.. you can replace them for few bucks ... if its a 2 piece agi.
Sep 07, 2007 | Washing Machines
I would make sure that the washer is properly leveled, and ensure that all sensors that check if the door is closed are working properly.
Sep 07, 2007 | Estate TAWB600JQ Top Load Washer
Washing Machines Logo
446 people viewed this question
Dan Webster
Dan Webster
Sal De
