Question about Intel D845GLLY Motherboard
Intel 845 chipset MB of Kobian make
My mother board gives 3 bips when memory is out of socket (as normal) but it has no display when I am putting the ram. I had tried two three ram but same result. What to do.
  • rpenc01 Sep 30, 2008
    Same problem when I tried to upgrade my RAM from 256M to 512M in each slot. In the past, had the same problem upgrading 128 to 256. Turns out, the only RAM I can get to work on this board is Micron (I am in no way affiliated with Micron). But I have tried several others and the same 3 beeps. Apparently the timing or timing info on the DIMM is not of high enough quality with the cheaper RAM. I'm sure other brands might work, but I have only had success with Micron. Be careful when you upograde RAM on this board that you verify it is compatible, That chipset seems particular which RAM it likes.
Tried much of the above, with no results. I finally gave in and ordered Micron memory, which worked great. I returned the cheaper memory to the seller. I never had problems with Micron memory, and it turns out the same happened when I tried using cheaper parts. I resorted to installing Micron. I am sure other brands will work too, but Micron is a known entity. I am in no way affiliated with Micron, just a customer.
Posted on Dec 08, 2008
In this position pl. chack 2.5v for ddr ram (replace f 73xx 8 pin smd near ram sockett)
thanks
Posted on Dec 07, 2008
Posted on Nov 21, 2008
  • 46 Answers
Try ramsticks individually (one at a time) in each of the memory banks until you get a post on the screen. if you don't get a post, then the memory might be parity and the board needs non-parity ***or vice versa***. Also, find the jumper on the motherboard for a bios reset, and reset the bios, then perform the previously stated memory tests.
Posted on Sep 26, 2008
INTEL 965 MB DRIVER
http://downloadcenter.intel.com/
download here, i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | Intel D845GVSR Motherboard
I HAVE AN INTEL D845GLLY MB WITH 1.6 GHZ PENTIUM 4 PROCESSOR AND 512 MB RAM AND VGA SUPPORT I HAVE INSTALLED WINDOWS VISTA BUT MY MOTHER BOARD CD DOESNOT RUN IN IT IT RUNS IN XP ENVIRONMENT AN APPCRASH...
today also some models of 845 chipset motherboards available in the market.Try to get the mother board cd of latest 845 chip set.
else you better go to xp
Jan 25, 2010 | Computers & Internet
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
Display driver for KOBIAN PI845GVM 5.0
hey u have an intel chipset mother board with 845 chipset just go to intel website and get ur latest driver directly this kobian /mercury website of ur manufacturer doesnt provide updated drivers just follow the links
for ur latest driver
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=865&lang=eng
or if u want from KOBIAN just go to this link and download graphics driver irrespective of motherboard model bcoz it has the same chipset as u have on ur motherboard just downlaod vga driver and install it will work
http://www.mercury-pc.com/downloads_list.php?productid=553
pls rate me FIXYA if i fixed ur problem
Mar 03, 2009 | Computers & Internet
I have intel 845 chipset gigabyte motherboard, no display problem
first turn off your computer or unplug it open your remove the memory card to the right side of the mother try to clean memory put it back again to the slot but be carefull put it properly and switch you computer
Nov 24, 2008 | Intel Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel D845GLLY Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
