Question about Foxconn 761GXK8MB-RS Motherboard
Power supply my monitor wont come on while hooked to this computer, but the machine lit up. could the power supply be the cause cause now it wont come on at all. the monitor does work on my other computer. one of the connectors on the power supply looks burnt, connecter #P1
  • 38 Answers
This is infact your video card and it can be the power supply if the burnt cable is connected to ur video card
the monitor is fine but about the burnt cable on your power supply
make sure you buy electrical tape and tape that up as soon as possible because if that burnt cable touches any part of your motherboard or anything else it will instantly fry everything which means damage everything which means ...
on the worst case scenario that has already happened
Posted on Sep 26, 2008
Hanns g hx191d no picture. My monitor went black while I was working, the green led is lit, I get a picture for a split second when I first turn on the computer or monitor.
The most common cause of this type of display issues is a failure of the back light power supply. There are parts called capacitors that fail and this causes the power supply to not be able to put out the correct voltages to operate the monitor. You cn repair the monitor easily by replacing the bad capacitors on the power supply board. The old ones need to re desoldered and the new ones soldered back in place. You can get a kit of the proper capacitors to do the repair here:
http://www.ccl-la.com/catalog/product_info.php?products_id=194
Nov 02, 2012 | Hanns.G Corporation HW191D 19" LCD Monitor
HP LE1901W won't stay lit up
usually with lcds, this can be caused by a bad inverter or power supply
Jun 20, 2012 | HP L1710 LCD Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hook up to the CPU
Two cables are needed, Power and Data signal (VGA). Most monitors take the same type of power cord as computer power supplies. (Some computers will allow you to plug in a slightly modified cable that will power the monitor off the computer's power supply. This cord has similar ends on both sides (with the prongs inside a rubber housing). The only issue with this is it makes the power supply work harder and thus can fail sooner.) Most computer supply shops (online and brick-and-mortar) will have the power cables, if you don't have extra cables hanging around.
I hope this helps.
Mar 20, 2010 | Gateway 7004618 (Black) 17 in. Flat Panel...
Monitor screen will not stay lit. It will only stay lit for a second then goes black.rq
The problem can be caused by bad caps in the power supply, bad inverter backlights circuits, bad lamps. Look for bad caps first, then post back what you find so we can guide you further, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | HP w1907 LCD Monitor
Monitor goes blank after a couple of seconds.
The problem can be the backlight inverter board or bad capacitors in the power supply section, I have seen bad soldering of the wires to the lamps are bad also.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 05, 2009 | Sony SDM-HS74P 17" LCD Monitor
Monitor totally blank
You have a power supply issue. Something is causing teh supply breaker to trip. You will need to find a local repair shop to pin point the issues.
Oct 03, 2009 | HP w1907 LCD Monitor
Laptop to pc monitor
Connecting the laptop to an external monitor hooked uip to the VGA connector at the back of the laptop cannot damage the laptop, even if the monitor is connected to a different power supply, as on the VGA port and cable there is not high voltage being carried.
Apr 05, 2009 | Computers & Internet
I have a Emachines w4682 and the monitor was showing no signal when I turned computer on. I hooked up a different monitor and that one worked so I re connected the original monitor and it worked I then got...
Possible reasons are bad power switch, bad power supply, bad motherboard, bad memory , device card is not seated properly. Suggest replace power cord to see if still no power, also you may want to remove cover and make sure all your memory and device cards are seated corrrectly. If you get a amber light at the power button, bad motherboard is likely cause
Mar 24, 2009 | E-Machines eMachines Desktop PC
HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
Jun 23, 2008 | HP Pavilion F1703 17" LCD Monitor
Foxconn 761GXK8MB-RS Motherboard Logo
69 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
