Question about Dell Inspiron 2200 Notebook
Dell "Inspiron 2200" PC Notebook Problem
When I try to turn on my laptop the first light is solid and the 3rd is flashing then the computer turns off
  • 46 Answers
Check dell's website for LED error codes. usually in a PDF file.
Posted on Sep 26, 2008
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
I got a laptop Dell Inspiron 2200...I turn the power on and all the four (4) green lights goes on then flashes a bit a wont turn on... ANY CAN HELP ME.... Thanks
If the the four lights on the computer come and then go off. Then these are the diagnostics lights telling that the motherboard has gone bad and needs a replacement
If they flash in some sequence . The the problem could be with one of the internal components.
For more information on the same you can visit www.support.dell.com
Thanks for using fixya
proton
Jul 28, 2010 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200; Win XP pro; detect router but no connect
Have you change settings on your router? if not try to disconnect and reconnect your dell computer. if still not working. turn off both laptop, turn off the router and modem. wait for 10-20 seconds then turn on the modem first, and if the modem is stable, turn on the router, and if it is stable, turn on the dell computer and try to connect. If still fails, try to delete wireless profile adn recreate it. If still fails, check device manger if there is a problem in your wireless driver. If still cannot connect, perform system restore.
Apr 04, 2010 | Dell Inspiron 2200 Notebook
Describe your Dell "Inspiron
The best solution is to re install your OS.
Jul 06, 2009 | Dell Inspiron 2200 Notebook
Dell inspiron 2200 need master password please
Password for what?
Operating System?
BIOS?
For BIOS try this Software:
http://www.4shared.com/file/82179383/4262ad3d/DELL_Bios_Pass_Killer_2008_By_Virility.html
Mar 19, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 won't start
First thing I would try is to unplug the machine, remove the battery and clean the contacts on the battery and in the battery housing with a pencil eraser. Blow out the shavings and reinstall battery - the way it sounds is that there may be dirt or corrosion causing an interference between the computer and battery contacts - for charging and powering up.
Feb 01, 2009 | Dell Inspiron 2200 Notebook
Brightness for Dell inspiron 2200
install keyboard drivers first and try...
Jan 17, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Laptop computer won't turn on
Hi tanya_alina,
I'm sorry to inform you that if that's how the lights acts when you try to turn your computer on, then the motherboard needs to be replaced. It could be caused by an improper shutdown or power failure. Call Dell and have it replaced if it still has a warranty. If not, then call Dell at this number 1800-2884410 to have an estimate on how much it will cost to have the motherboard replaced.
Hope you find this information useful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
93 people viewed this question
Alun Cox
