Question about Jenn-Air JCD2290HES Side by Side Refrigerator
Jenn Air JCD2389 fridge not cold on fridge side
I have an 8 year old Jenn Air JCD2389 fridge that is not cold on fridge side. I cheched for the frezzer fan and for frost/blockage on the freezer side but everything looks good there. For a few months I heard what sounded like a fan blade that was a little off kilter on the fridge side and now there is no cold air blowing from the vent on the top of the fridge interior. Any reccomendations on the cause and the solution?
  • rrt7 Feb 05, 2009
    mine is cold but not cold enough and the damper is on coldest the freezer works fine just frig is not as cold as it should be
  • Anonymous Feb 06, 2009
    If this happens every month, how can it permanently be resolved?
    Thanks
  • 4,889 Answers
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Posted on Sep 27, 2008
  • johnandbeth Jun 04, 2011
    The drain isn't clogged for me, so what should I check next?
I have a Jenn-Air JCD2295KES side-by-side - freezer fine but the fridge too cold
The thermostat is not registering temperature correctly. If you have thermistors they should be replaced
Feb 27, 2014 | Jenn-Air JCD2295KES Stainless Steel
Hello...we have a JCD2289AT that is 6 years old approx...frezer and ice maker are working fine butr refrig seems to not hear a cold temerature even after setting to the coldest setting. I pulled the unit...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2010 | Jenn-Air JSD2789GES Side by Side...
Freezer coils icing up, refrig not cooling 8 years old expensive where is thermostat control
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 17, 2010 | Jenn-Air JCD2389G Side by Side...
I have a 15 year old Jenn Air Fridge/freezer Model no JRSD249OT . Recently side of doors feel hot and now fridge not getting cold. Appreciate any advice
You will need to pull the fridge out and remove the rear lower panel. If the unit is operating you will be looking to see that the fan in the rear is also operating. Most likely it is not. You will need to replace that fan motor if it is not.
May 21, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
1,015 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
