Question about Kenmore Dryers
Kenmore 29-inch wide gas dryer will not start
Went through troubleshoot like checked recepticle, checked circuit breaker, confimed power running to switch to push start.
What else can I be checking?
  • 943 Answers
Hi thanks for the question you could have a broken belt check that thanks te appliance doc
Posted on Sep 27, 2008
No heat gas kenmore gas dryer
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 03, 2009 | Dryers
Kenmore 110 66862501 won't start
Do you mean you checked the outlet and breaker and that wasn't the problem, or you have no power there? I can't imagine anything the servicer did that would have required shutting off the power, only to unplug the dryer. The door switch probably isn't working still and the machine won't run because it thinks the door is open. Call the servicer back to check. You should be covered by some kind of warranty for the repair parts and labor.
May 21, 2009 | Kenmore 70172 Gas Commercial Dryer
The kenmore series 70 dryer stopped running aand i can't get it
Unplug the dryer.
Remove the rear panel and check the thermal fuse attached to the left side exhaust vent. The fuse is 1 and 1/2 inches long by 1/2 inch wide and white in color.
No continuity on a volt meter is a bad fuse. Replace it.
Apr 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer
Hi!
Heating element
Thermal fuse
Wiring
Heating element
Thermal fuse
Wiring
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
My Kenmore Dryer (GAS) heats for awhile then stops heating.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 08, 2008 | Kenmore 73952 Gas Dryer
Kenmore 73932 gas dryer
Heating element
Thermal fuse
Wiring
Nov 05, 2008 | Kenmore 73932 Gas Dryer
No heat
Heating element
Thermal fuse
Wiring
Aug 22, 2008 | Kenmore 74832 Gas Dryer
Kenmore HD gas dryer won't heat up
Heating element
Thermal fuse
Wiring
Jul 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dryers Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
