Question about GE Tritonr XL GSD6260JCC Dishwasher
When I put my key into the ignition, it won't turn. It's stuck. What could be the cause and what can I do to start it up?
  • marlcie Sep 26, 2008
    Hey my bad. I typed in Mitsubishi Triton but looked like there was no match and it just came up with the closest one which was the dish washer.....Sorry about that, should have checked before posting
  • 1,543 Answers
Don't see where this dishwasher uses a key. You might try posting under another area. (at least if turning the wheel hard left and right does not help)
Posted on Sep 26, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 26, 2008
    Hey, you posted this as a GE Triiton XL GSD6260JCC dishwasher. I just pointed out that you would have better luck posting under another heading. My response was not inappropriate, but your rating sure was.
Ignition of ford edge will not turn completely off..it is stuck in position 2 in auxillary power
1-
My ignition key will not turn to off. I can remove the key, but it stays in the accessory mode. What's the fix?
My ignition key will not turn to off can remove the key but it stays in...
2.
Ignition key is stuck and does not turn Inspection Service & Cost
Ignition key is stuck and does not turn Inspection Service Cost...
3.
Ignition key won turn
Aug 24, 2016 | 2012 Ford Edge
How do i get my ignition to to turn if it is stuck?
Sometimes the steering wheel lock can bind up causing the key to be difficult to turn. Try turning the steering wheel one way and then the other while trying to turn the key. It sometimes works.
Sep 17, 2014 | 2000 Chevrolet Monte Carlo
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
Stuck eldorado key in DTS ignition now car won't start
Make sure your steering wheel isn't locked. Sometimes a key won't turn until you jiggle the wheel while trying to turn the key.
Aug 21, 2012 | 2004 Cadillac DeVille DTS
Ignition key won't turn
Try turning the key while jerking the wheel left and right and depressing the brake pedal. If that won't work try another key.
Oct 17, 2017 | 2002 GMC Sierra 1500
I put key in ignition and it won't turn. Steering wheel will turn but key won't turn. We have 2 keys and neither will work. What can I do?
If the wrong key was inserted it may have bent a tumbler pin,maybe try some wd-40 or similar and work it with the right key,might drop the tumbler back,,if not the whole ign. cylinder will have to be changed
Jan 26, 2012 | 2007 Cadillac CTS 3.6L
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
Aug 05, 2011 | 2005 Chevrolet Monte Carlo
My 1998 Olds Bravada has the key stuck in the ignition. I paid to have a new ignition key cylinder put in, but the new one does the same thing. The key will start the car etc. but won't come out of...
I know in the newer versions of the Bravada, Trailblazers, Envoys, the ignition switch itself is always the culprit. Not the switch the key goes in, but it's located under the steering wheel column. I know how to replace the newer ones but not yours. That's the first place I'd look.
Jun 07, 2011 | 1998 Oldsmobile Bravada
My steering wheel is stuck and when I put my key in it won't turn either. It starts to turn but won't go all the way
hi,it maybe a good idea to remove the steering collum covers to visually inspect it can be the ignition bolt just being loose or the steering lock or ignition it self is on its way out.
May 19, 2011 | Volkswagen Jetta Cars & Trucks
GE Tritonr XL GSD6260JCC Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
