Question about Zenith LST3100A DTV Receiver
LST-3100A "HELLO" msg
All the unit says in "HELLO" on it's display. I can not turn the unit on/off with either the front power button or remote. When I unplug the unit and plug is back in, it comes back with the "HELLO" message.
Help!!!!
Got you some help!! Open receiver up...Locate the power supply board. Locate the electrolytic capicitor "C118" and replace. II've fixed multiple LG LST 3100a receiver doing this procedure. Guaranteed to work. I hope you have not throw it away. Cheers!!!!
Posted on Mar 03, 2010
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
My aiwa tv has been locked through remote......so what can i do?
With the TV turned on, simultaneously press VOLUME down button on the front of the TV set and the number 7 button on the remote control to reset pin code and customer ID.
Dec 27, 2012 | One For All URC-4330 Remote Control
The LST 3800 powers up and on the display it shows backlight. every now and then it will cycle through the optional menus. When I press the menu button or the up and down buttons nothing happens.
I just purchased a 2007 VIP Vantage with an LST 3800 and it was experiencing similar problems. I noticed that the "UP" button didn't feel right when pushed, so I pulled it out of the dash and used a very small screwdriver to gently pry off the front bezel. There's a clip on each side that holds it in place, and it's fairly easy to remove. The rubber button pad had a tiny piece of plastic (it was the same material and color as the plastic in the bezel) between the bezel and the button pad that was causing the "UP" button to depress constantly. I put the button pad back into the bezel, snapped it back on and the depth sounder is working fine. Best of luck.
May 12, 2011 | Lowrance Lst 3800 In Dash Digital Depth...
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Jan 13, 2008 | Televison & Video
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
LG HGTV STB LST-3100A No scan no menu
Make sure you have an antenna hooked up to the antenna connector on the back.
Aug 29, 2007 | Computers & Internet
Child lock?
To turn on the dealer lock function: Turn the DVD player on. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds. Note: When the dealer lock function is active, DEALER LOCK ON or DEALER LOCK OFF scrolls on the FLT display. this is from samsung's site
Jun 07, 2007 | Samsung HTDM150 System
Televison & Video Logo
248 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
