55" philips rear projection Tv model 55pp970104 with no red or intermitting red .
  • 8,617 Answers
Sounds like a defective red CRT drive PCB. You will need the one for the DPTV 300 series Phillips. You should be able to get a replacement at the following link.
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
Cant change channel and/or input mode, picture is horizontally scrambled?? Philips 55PP970104
Possibly, your small signal board needs replaced! It is usually located on the left side on the backside of the tv. It is inserted into the convergence board. This is a good place to start. Hope this gives you an idea to speak with a TV tech!
Jan 17, 2010 | Philips 55PP9701 55" Rear Projection...
OK friends. You've helped me with a TV once before. Now I need your help again. I have a 55 inch Phillips rear projection. Model# 55PP970104 Serial# 58610822 Chassis Model# DPTV210 born on 6-13-01 I bought...
sounds like loose solder or crt board...hard to say.
I have the exact set in the shop - same problem - but I have not gotten around to playing with it...
Mine does the same...warms up - works...
Email www.TvRepairKits.com - they may be able to help.
Ed
Jun 10, 2009 | Philips 55PP9701 55" Rear Projection...
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 55 inch rear projection tv
When it is on, do you see any distortion in color?  If not probably bad power supply board. Call 1-800-543-4330 and have model and chassis number and ask for Power supply/deflection board. Only about 200.00
May 29, 2008 | Philips 55PW9363 55" Rear Projection...
Green tint screen
Took mine to a repair shop and they said there was an issue with the line something? circuit board. Quoted me 225 parts 450 parts+labor. Mine was a red tinted screen.
Jan 17, 2007 | Philips 55PP9701 55" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
