Question about Acer Aspire 5315 Notebook
Asking a BIOS "Enter CURRENT Password".
This morning I found it asking a BIOS "Enter CURRENT Password". tried clicking the alt F10 nothing works.just purchased. Acer wants to charge me $99 to look at it.
  • 1 more comment
  • CLIFGORDON20 Feb 11, 2009
    forgot password bios asking for password I do not know can you please help , just purchased 1/2/09 email me @ clifgordon2000@yahoo.com if you have solution
  • Anonymous Mar 18, 2014
    When I turn on my acer d-257 it comes to a grey screen asking for "current" password...? It's not the windows login menu either.
  • Anonymous Mar 26, 2014
    when switched on an acer aspire is stuck on enter current password message / i dont have the password
  • 4,889 Answers
Its very simple. You can reset it by removing the CMOS battery and then putting it back in. You will have to remove the back panel of the laptop to get to it. This is what a CMOS battery looks like http://www.computerhope.com/issues/ch000239.htm
Posted on Sep 26, 2008
  • 44 Answers
How do I get past theYour pc will restart in 2 days to finish installing important updatesIt won't let me enter my password to unlock the pc
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order
If this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jun 23, 2013 | Acer Computers & Internet
How to reset bios password of hp 2530p notebook? a) Flashing BIOS anew won't work (password required) b) Removing RTC battery inside for one hour won't work either
o check the current BIOS version on the computer, follow the steps below:
  1. Click Start , and then click Shut Down .
  2. Select Restart , and then click OK .
  3. When the first screen appears, press F10 to enter the BIOS Setup.
  4. The BIOS revision is listed on the Main menu.From there look for administrartor password and disable it. Make note of the current BIOS version; you will need this information to determine if a newer revision is available.
  5. To exit the BIOS setup, press F10 , select Yes , and then press Enter .
Nov 28, 2010 | HP EliteBook 2530p Notebook
When turning computer on boot start and freeze when screen show F2 F12 . Nothing else work no matter what key I press. It wont even turn off unless we disconnect power supply and remove the battery.
It may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to
the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now,
restart the computer and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are
prompted), it will restart the computer. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e
Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 27, 2010 | Acer Aspire One PC Notebook
How to restore fatory settings without the cd acer aspire 5740g windows 7 home premium windows is not booting n auto recovery that is alt+f10 is also not working but the recovery partition still exist
For all Acer Netbooks try to initiate the recovery using Altgr key (righthand side of the space bar) and F10, ie Altgr+F10 as soon as the computer restarts. If the recovery partion is corrupted or do not have the CD. Try the below steps:
No Restore CD / eRecovery / password / ALT + F10 or F10
1 - Recovery of data on the hidden partition PQSERVICE for password
A - Installing the software R-Drive Image to create an image of this partition (this file has the extension. ARC)
B - Always with this software, create a virtual disk logic to see the files
C - From the desktop, go to the newly created virtual disk and find the file aimdrs.dat. The open with the notepad and get the password.
2 - Reactivating the ALT + F10
A - Always on the virtual disk created, find 2 files: mbrwrwin.exe and rtmbr.bin.
B - Copy these 2 files on drive C: \
C - Since the MS-DOS (Pocket PC) to C: \, type the following command: mbrwrwin install rtmbr.bin
D - The function has been reactivated.
3 - Start of Restoration
A - At the start of the PC, go to the set-up to check if the function is well on D2D enabled (normally it is a default setting ... but hey you never know.)
B - Once the audit and that the PC has restarted once the ACER logo appears, simultaneously press ALT + F10 to start the restore utility.
C - When it asks for the password, you need to type one found in the file aimdrs.dat. CAUTION: The keyboard is QWERTY mode so we thought enter his password, but as some letters are reversed, it does not work.
4 - Normally at this stage there ... everything works and restoration is smooth.
Note: If the operating system does not work, it is possible to do this from another PC by connecting the hard drive or USB slave
i found this helped me with exactly the same problem you have on the 7540g aspire laptop use the ALTGR on the right hand side of keyboard not the ALT on the left hand side of the keyboard along with F10 i tried it with just the ALT on the left side nothing happened but when used ALTGR on right side it woeked and reset everything back to factory settings then went to acer site and downloaded missing drivers hope this helps you out
Jun 24, 2010 | Acer Computers & Internet
How do i put my laptop aspire 9300 back to factory settings
To Recover your system from within Windows
1. Click on Start, then All Programs, then Acer Empowering Technology.
2. Click on Acer eRecovery Management.
3. If prompted to create a password, create the password and hint
Do not lose this password.
If asked for a password, enter the previously set password.
4. When the Acer eRecovery Management loads click the button labeled Restore.
5. Click on Restore system to factory default.
6. The unit will restart and start the restore.
It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
7. At the eRecovery Management menu it will ask you how to restore.
Click on the restore option you would like to use.
To recover your system from bootup
1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
2. Power the system on.
3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
4. At the eRecovery Management menu it will ask you how to restore.
5. Click on the restore option you would like to use.
Jan 31, 2010 | Acer Aspire 9300-3716 Notebook
Press delete enter to set up so what can i do nothing is working
Sound you are trying to get into the BIOS, some use key F2,F8, or F10, it will say very fast what the correct key is, it might be very fast.
The first item is the key or key combination. The second is the model of PC or the maker of the BIOS. You'll see some companies listed many times, with different keystrokes. That's normal. (It's not that manufacturers can't make up their minds. It's just that they change suppliers and use different BIOS setups.)
Delete: AMI or Award BIOS.
Esc: Toshiba
F1: Toshiba; Phoenix; some IBM PS/1 models.
F10: Compaq.
F2: NEC.
Insert: IBM PS/2.
Tab: eMachines.
Reset button (press twice): Some old Dells.
Ctrl-Alt-+: Various computers.
Ctrl-Alt-?: Some old IBM PS/2 models.
Ctrl-Alt-Enter: Some Dells, others.
Ctrl-Alt-Esc: AST, Tandon, others.
Ctrl-Alt-Ins: Zenith PCs, Phoenix BIOS.
Ctrl-Alt-S: Phoenix BIOS.
Ctrl-Alt-Shift with Del (on number pad): Olivetti.
Ctrl-Esc: Many PCs.
Ctrl-Ins: Some IBM PS/2s.
Ctrl-S: Phoenix BIOS.
Ctrl-Shift-Esc: Tandon
Dec 02, 2009 | Acer Aspire™ T180 PC Desktop
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Aspire 5315-2326 enter Current password problem
i think is a factory fault most systems comes with factory passwords like that.
now u must find out if its a hard drive password which i dont think is thru.if its a bios password then u will need to erase the bios chips which is a risky thing to do if u r not an expert.
my advise,
hard drive password can not be recovered all u do is change a hard drive.
bios password can be erased if u meet an expert.
i suggest u give them d 100 dollrs n get it fixed.
hope this helps
Dec 27, 2008 | Computers & Internet
Enter current password
if you want to restart your computer you can push Alt and f10 as soon as you see the acer logal. just push alt then f10 then alt then f10 untill it comes to this page where you can restart your computer but it will be set back like if you just got it and if it came out of the box so everything will be erased
Jul 23, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
1,061 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
