Question about Toshiba MW20FM1 20 in. Combo
Toshiba MW20FM3 Remote not working - new IR Receiver
Hi Mike, I have a Toshiba TV/DVD/VCR Combo Model MW20FM3 and the original remote does not work. I then bought a replacement remote (part# 72796927 - this is the replacement remote that both replacementremotes.com and partstore.com said to use), put new batteries in it and that doesn't work either. This leads me to believe it's a problem with the IR receiver. So I pulled that out, but I don't know where to find a replacement IR receiver, nor do I know how to determine what kind (i.e. what kHz, etc.) I should be looking to buy. Could you tell me how to determine specs to look for in a replacement IR receiver? I see that RadioShack has a 38kHz IR receiver with 3 prongs like the one I pulled out of the TV, but how can I tell if this is compatible and which holes to solder the new prongs in (i.e. are the placements of the 3 prongs on all IR receivers standard)? Thanks!
  • 3 more comments
  • Anonymous Nov 03, 2008
    ditto
  • mcarroll1 Nov 10, 2008
    I play with the batteries - replace them - then all of a sudden it works for 2 or 3 operations - then not again.
  • indylaw Nov 15, 2008
    Same problem on a 27" RCA
  • rlatt Nov 17, 2008
    mw20fm3 new remote not working either
  • warfort Feb 16, 2009
    remote hasn't worked. sometimes it does, usually doesn't.
svenby
  • 66 Answers
SOURCE: Remote Control not working
you can easy check if you existing remote really work just look on the IR led with a digital cam and u will be able to see the led flashing
Posted on Feb 05, 2008
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Posted on May 12, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: I have toshiba tv vcr dvd combo. I the clicker
TRY NEW REMOTE OR SENSOR BAD ON TV
Posted on Aug 24, 2009
Testimonial: "Where do I get a new remote?"
AJIN G
  • 6694 Answers
SOURCE: toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jan 07, 2017
andygoacher2
  • 17 Answers
SOURCE: My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Posted on Jan 08, 2017
Remote doesn't work. have purchased after market units and they don't sync up either? What to do?
Return the tv universal remote where u bought it,get ur money back.If none of the tv univeral romote programming codes on the owner manual codes for ur tv make and model don't even work and don't have any responses for ur tv make and model functioning all.Try website like Remotes.com to buy the tv original remote or a very closed compatible clone one.
Sep 03, 2011 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
I'm getting tired of trying to get the correct code so that a radioshack remove control will work with a toshiba tv/dvd/vcr combo, model MW24FP3...any ideas?
Than u must used the original remote,still have it,not.Try website like Remotes.com to buy an exact remote to the original remote.
Oct 22, 2010 | Toshiba W603 VCR
I bought a replacement remote control for my tv and doesnt work, how do i get it work? I put fresh batteries, reset the remote, and pressed the tv/dvd button. model MD14FP1
Have you make sure you were sent the correct one, according to the info for the model you give the replacement remote should be a 72796929 and it's available through the partstore.com for about 10 dollars. If you got a universal or programable remote then you'll have to try the code search procedure listed in the instruction manual. If you have the correct remote(part number) then there is a problem in the IR receiver panel or the IR receiver itself. If you have a universal remote you might want to try the dvd codes also because you have the combo/TV
Apr 07, 2010 | Toshiba MD14FP1 14 in. TV/DVD Combo
I lost my original remote for my toshiba tv model MW20F51 and found a toshiba wc-sb2 remote. is there any code i can use to sync them
No.Might some functions work, because they are both toshiba tv.Try website 1-800-Remotes Factory Original.Get the sanme exact remote or very simular.
Feb 04, 2010 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Our Sylvania tv/dvd/vcr combo remote is not working and it is a new remote
If the remote is new and OK, then my opinion is the Ir Receiver on the front panel of your TV set is burned, replace it with new ones will solve the problem.
To locate it, follow the Ir receiver that written on the front panel of your TV, behind it is the Ir Receiver .
Oct 23, 2009 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Feb 05, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba MW20FM1 20 in. Combo Logo
473 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
