Question about Gateway 510 X (10272197) PC Desktop
Won't boot Was working. I installed a gforce 6200 agp graphics card and a 480 watt power supply. This was supposed to work. Didn't. Now computer will run but no screen. Can't get into safe mode or bios or anything else. theearl134bid@gmail.com
  • force 1 Sep 26, 2008
    I tried doing just that but the computer would not recognize the cd. The
    problem is that I cannot get any screen what ever I do. Could the 480
    watt powers supply have been to strong for something? How would one know if something has been destroyed?
    President:
  • 1,901 Answers
Is there nothing at all on the screen? If you are seeing nothing at all, I'm guessing the new graphics card is not working. Try an old card to see if something shows up. BTW, having a 480 watt power supply shouldn't affect anything. It just allows you to power more things.
Posted on Sep 26, 2008
  • 781 Answers
Are you possitive your motherboard support this card? check the documentation for your motherboard and double check.
use another video card, one that would allow you to see the screen, go into your bios and disable the onboard video then try again with the gforce 6200 agp graphics card.
  • 4,889 Answers
You will need to flash the graphics bios of you comp. Put the CD that you got along with the Card and reboot your computer and then follow the onscreen instructions to flash it.
Let me know if you need more help!
Regards,
Sai.
I have a Sony Vaio VGC RB-40 Desktop PC. P-4 3.00GHz. 2.00GB. Ram 32 Bit system Win 7 Home Premium 300 Watt power supply I need a video Card 1GB DDR3
Hi,since your computer is P4 3.0ghz,your looking for agp 6200 graphic card..and not the 1 gb ddr3 because this is pci-e and its not compatible with your slot..I can offer to you is the 256 mb agp video card,coz its hard to find now the 1gb ddr1 coz its all absolute now.thanks
Aug 20, 2011 | Nvidia GeForce 6200 AGP Graphic Card
I want to install a gts 250 graphic card on my pc this card want a 8 pin wire and my power hasnt it there is a reduction which want 2 (6 pin) wire and my power has just one 6 pin wire can i use my...
No, if you attempt that then your computer with either not work because of video card errors, or it will boot up and run for a couple hours and then the graphics card will most likely melt due to insufficient power to the fan. Your best bet is to return the video card and buy a video card that is compatible, or buy a new power supply with the connections that you require.
Jan 13, 2011 | Intel Power 480W 480 Watt Pentium 4/ AMD...
Hello i can't install a AGP 512 videocart I bought
your computer needs more than the video card ram amount to use a particular video card. if you do not have at least 512mb of system ram, that may be your problem. if you have sufficient ram, then you do not have a powerful enough power supply for the new card.
Nov 22, 2010 | EliteGroup KV2 Lite (V1.0) Motherboard
Werticle lines in pairs of four and long startup wait
your card is pulling too much power. check the wattage rating of the card and the wattage output of your power supply . good rule of thumb you want about 20% more that your card rating 450 watt card needs 650 watt power supply to run well. the extra is for your other stuff (dvd burner ,ect)
Feb 11, 2010 | Nvidia GeForce 6200 AGP Graphic Card
ATI Radeon 1650x Problem in Installation
This one is simple, the computer's stock powersupply which is probally at about 250 or 180 watts isnt generatiing enough power to the Vcard. Basically you need to purchase a higher watt power supply, you can get a decent 400+ watt for under 40 dollars almost anywhere.  Just a simple swap will do the trick.
Sep 22, 2009 | Computers & Internet
Video
go to Nvidia web site and dowload the correct driver for the OS that you have.
Apr 01, 2009 | Nvidia GeForce 6200 AGP Graphic Card
New Geforce 6200 on AGP 8x slot has no output
if you can't get a display from the onboard vga the PSU must have killed the mother board. the 6200 gets all of its power from the AGP slot. so if the PSU killed the 6200 it must have gone thru the motherboard. it does not seem likely it took out the 6200 but nothing happened to the board. try taking out the RAM modules. if the computer does not beep then most likely the motherboard is dead.
Jan 31, 2009 | XFX GeForce 6200 Graphic Card
Gateway 510 X (10272197) PC Desktop Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
