Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 55 inch hdtv lamp
When projection lamp went out on my htdv toshiba 55 inch tv , the tv said it was the lamp. Is this common? voice activation.
  • 185 Answers
This is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Posted on Oct 08, 2008
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
Picture went blank. Still have sound. What is wrong?
When was the last time,this tv the projection lamp was replaced?The projection lamp in the tv now,has not been replaced the last 1 1/2 or 2 years.The tv been on and watches 4 or 5 hours a day.The projection lamp life span is over.Require a new projection lamp.
Aug 11, 2010 | Philips 55PW9363 55" Rear Projection...
The temp and lamp light start blinking when i turn on the tv and the screen is black and the lamp light stays on hitachi i think it is a 55 inch model # 55vs69a
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Jul 10, 2010 | Hitachi 55VS69 55" Projection HDTV
Tv lamp light stays on.
The projection lamp inside on this tv,about 1 1/2 or 2 years,tv on and watches about 4 or 5 hours a day?The projection lamp life are over.Tv require a new projection lamp.
Jul 05, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
55 inch hitachi lcd projection tv has yellow and purple blur near the center of the screen
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses on one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and visually inspecting the lamp itself and the lens that it shines onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Have a tech confirm-Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Hitachi 55VS69 55" Projection HDTV
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Sony Wega 55 inch, won't turn on and displays shows lamp problem? How do I resolve this? Thanks
Please replace lamp in TV and lamp replacement procedure is written in user manual of TV.
Please buy Sony original lamp for your TV and avoid aftermarket / cheap lamps.
Need further info, let me know with model number of Sony TV.
Apr 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi 55 inch 1080 tv
Is it flashing a two digit code such as 34 as thats a common fault with the WD52525 V26 chassis for a lamp abnormality caused by two bad capacitors on the PWB PCB
Jun 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
353 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
