Question about Minolta Office Equipment & Supplies
K M magicolor 2530DL has a vertical skip of about 3/16 of an inch wide and about 1.25 inches in from the left edge of paper. Same skip no matter if printing in color or black.
  • Minolta Master
  • 6,168 Answers
Replace the fuser unit or is it with the black only replace the black image unit.
try this ite for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Nov 22, 2015
Soulvisitor
  • 1113 Answers
SOURCE: Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Posted on Nov 18, 2007
  • 4 Answers
SOURCE: Faint Black Lines
Did you re-fill the black toner cartridge with genuine Ricoh toner or from somewhere else? It might be the wrong granularity.
Posted on Feb 09, 2008
SOURCE: magicolor 2530dl
IF YOU LOOK AT THE PRINTER FROM THE TONER BOTTLE END THERE IS A SMALL CLUTCH IN THE TOP LEFTHAND REAR CORNER OF THE PRINTER.
YOU WILL NEED TO REMOVE THE TOP COVER TO ACCESS IT.
IT IS BEHIND A PLATE BUT FASTENED TO THE MAIN FRAME OF THE PRINTER.
YOU NEED TO SPRAY INTO IT WITH SOME LUBRICANT LIKE WD40 NOT OIL.
THIS CLUTCH GOES RUSTY AND DRIVES THE CAROUSELL SO GIVES 15H CAUROSELL ERROR
Posted on Nov 14, 2008
  • 95 Answers
SOURCE: Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Posted on Apr 23, 2009
  • 19 Answers
SOURCE: Since replacing the fusing unit on my Magicolor
faint prints wont be from the fuser. if u can physically rub the image off the paper with your hand then your fuser is faulty. check condition of the drum unit. if a new drum doesnt fix this then u have a dirty laser which will need a tech to clean.
Posted on Jul 16, 2009
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Red dots appear about one inch from the left edge.
There is possibly something on one of the magenta rollers inside the imaging unit. You could inspect the imaging unit and try to locate the debris, possible removing it with a q-tip or other soft device.
The Xerox Phaser 6200 is the same as your Minolta. Xerox made a cleaning device for this. See the document at this link: http://www.xerox.com/office/out98kb/,case=83590
The cleaning tool referenced is available for $75 plus shipping (usually $15 overnight).
Apr 09, 2009 | Minolta magicolor 3100 Laser Printer
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Smudged printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Black strip over all printed papers
Check your Drum cartridge, if you see your strip replace it....If it's not the problem you may have a bad Fuser ....
Mar 25, 2008 | HP LaserJet 1100 Printer
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Jan 24, 2008 | Ricoh Aficio CL3500N Laser Printer
37 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
