Question about Maytag Dishwashers
Maytag newton iowa 50208 u.s.a. e39927 lr111720 pdbtt49aww 26359287gc motor 2.2a heater505a max load 9.0a dishwasher wont drain
2 Suggested Answers
  • 672 Answers
SOURCE: iI need an owners manuel,
Take this link to Maytag and scroll down the page to find a list of owner's manuals to choose from.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDBH965AWB&siteCd=MT_EN_US&userType=Consumer
Posted on Oct 12, 2010
Maytag 4000 series washer mhwe450wr01 just beeps once when I press the power button
Maytag's address used to be #1 Dependability Blvd, Newton Iowa. Not any more. Now they're made elsewhere by a company that bought the name and not the quality.
Oct 14, 2014 | Washing Machines
Wave runner has trouble starting when warm
http://maar24.com/maytag-appliance-repair-service/
Maytag is an American company that manufactures home and commercial appliances. Their headquarters is located in Newton, Iowa. This company has been producing great equipment's since it was founded in 1893. Currently, this brand is being owned. This brand produces different kinds of kitchens or home appliances such as ovens, dishwashers, food-waste disposers, refrigerators and others. Through the history of this corporation, it has introduced a lot of equipment's making it an important contributor to the development of home appliances.
Jan 08, 2018 | Yamaha Cars & Trucks
I have an E39927 Type 776-0 dishwasher. The problem began this week, in that water does not fully drain from the dishwashwer following the end of any of the washing cycles. The unit seems to be...
disconnect the drain hose from under the sink. place it into a bucket and put the dishwasher to drain. if it drains in the bucket fine then you know you have a problem with your drain. if it doesnt drain, then the problem is most likely the drain pump
Oct 23, 2011 | Maytag Dishwasher
MAYTAG PERFORMA PDBTT49AWW, SN 10120630ET - Under counter model, ABOUT 6 YEARS OLD. No longer gets dishes clean. Problem got progressively worse over 2 year period. After washing cycles, the inside of...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 22, 2011 | Maytag Dishwashers
How far away can you drain hose be from dishwasher to drain
The max is usually around 20 feet. Any longer and you will have water back up into the drain and stink.
Nov 30, 2010 | Maytag Dishwashers
Maytag dishwasher will not drain
Drain Tube could be clogged....Have you disconnected the outlet drain tube from the motor to the disposal/sink/drain?
Aug 11, 2010 | Maytag MDB5100A Dishwasher
Glasses and others things are not getting clean in the upper rack. A white film remains on the glass and stains are not removed. Also I'm having trouble with the silverware showing rust spots and not...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Other things to try: CLR on the spray nozzles to loosen up cloggs.Check the filters to be sure they are clear.
Jul 30, 2010 | Jenn-Air 24 in. JDB1270AW Built-in...
Goes thru cycle but wont drain, check filter ok , water sits in t
Check the pump motor for obstructions like: broken glass, paper from labels, food. Also some maytags have a cover screen... check that it is not filled with debris (****)... How old is the unit?
May 15, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Water will not drain on neptune MAH3000AWW washer tried different cycles. It started working for a while after we took back off and took things apart but now it won't drain at all.
There are many things could make a dishwasher not drain, here's a list of the most common reasons.
  • a clog or air gap in the drain line, often the problem is where the drain line attaches to the household drain line, if you remove this line you can clear any debris from the hose or hose connection.
  • a defective pump, your dishwasher pump ejects the water.
  • many dishwashers use a drain valve or solenoid, the solenoid can sometimes become stuck or defective solenoid.
  • a defective motor, if the motor is'nt turinig or working the dishwasher won't drain.
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dishwashers Logo
370 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
