Question about Alpine CDE-7870 CD Player
Setting clock on alpine cdm com-7874
Need info on clook setting for this radio/cd
3 Suggested Answers
Char1ieJ
  • 100 Answers
SOURCE: Setting clock
From the Owners Manual for the CDE-9874:
FixYa won't allow images larger than 150k, so that's why this is a little blurry.
I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Posted on Nov 18, 2008
SOURCE: set the time on Alpine CDM 7874
turn off ur unit then ull just see the time on then u can set it up!
Posted on Mar 14, 2010
Replacing radio in 1995 nissan altima and need color codes
Here it is
http://internetautomart.com/albums/Junk-3rd-gen/radio_harness.jpg
May 13, 2011 | Alpine CDM-7874 CD Player
I was wondering does the Alpine CDM-7874 have any code. I just bought a car with this system in it and it had a dead battery and the stereo is not working
There should be no code. If you can try to see if you can check to see if power is getting to the red and yellow wires on the back of the radio. If there is a reset switch, try pressing that. It should be a small depression about the size of a pencil tip on the face or a hole with a red switch behind the face on the subpanel.
Apr 24, 2011 | Alpine CDM-7874 CD Player
Set the time on Alpine CDM 7874
Mar 14, 2010 | Car Audio & Video
Alpine CDE-9845, no audio from cd's either normal or mp3. Tuner works fine. Where to troubleshoot?
You have the wrong blue wire connected.
Your power antenna wire is hooked to the amp remote wire and vice versa.
Your radio thinks the tuner is off - and is dropping the signal thru the power antenna wire - and turning off your amplifer.
Switch the 2 blue wires in your install - and you'll be all set.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 06, 2010 | Alpine CDM-7874 CD Player
Alpine CDM 7874 won't play rest of CD after track 1.
It could be a bad burn or an issue with the receiver. Try re-burning the CD and see if that helps.
Jan 14, 2010 | Alpine CDM-7874 CD Player
Connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Mar 20, 2009 | Alpine CDM-7874 CD Player
No Sound
There should be a fuse on the back of the radio. It needs to be checked.
Feb 06, 2009 | Alpine CDM-7874 CD Player
WIRING ALPINE CDM-7874
I need a wiring harness that plugs into the back of alpine cd player cdm-7874 & a user manuel
Sep 25, 2008 | Alpine Car Audio & Video
Setting clock
Regards,
Char1ieJ
Sep 14, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Alpine CDE-7870 CD Player Logo
146 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
