Question about Toshiba Computers & Internet
I have a p35-s609 can not run on AC power, lits in front on,ok battery charges but when dies it will not run on the AC power. Also when you turn off the the button stays blue and you can not start back up until you unplug it and plug back in, it charges and runs till it dies
  • 781 Answers
Usually when you have power problems are associated with a dying battery.. have you tried replacing the battery? there's no much you can do besides replacing the battery, getting item serviced (which may cost as much or more than the laptop (if old) or getting a new laptop.
Posted on Sep 26, 2008
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
Good luck Hope that helps
May 21, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba P35-S611 wont power on! When i plug it in no led lights come on, i get nothing out of it. the led on the battery charger lights up but nothing on the computer, someone said maybe the motherboard? ...
yeah if you are planing to do it yourself..it is worth ..I just bought last week a broke one and I payed something under 100$ ..and I changed the motherboard in one that was doing the same..so ...if you think you will use it ..its worth looking on ebay ..or parts to buy what is missing
Anyway check the power line on the motherboard ..it may be just something unplugged..or a little part..but if it does not get any power..its just that ..
The fact that is charging the battery it means that the power is ok from the charger and the entry on the board...so check the ram memory ..and the power cable of the board...cause if the charging is ok ..and the fan is working ..it may be something like a cable or the switch itself..( in this case the switch board is changeable in a few minutes and has just a plug and 2 screws..
May 08, 2010 | Toshiba Satellite P35-S611 Notebook
My toshiba Satellite P35-S609 started not charging. The charge connector seemed not working. I gave it for repair, and the person told that one module which connected the charge chord to the mother board...
Seems a bit odd that the inverter would fail immediately after a repair job that involved the power jack since the inverter is built into the screen housing or lid leaving only a single connector to disconnect then reconnect (aside from the wifi antenna wires) If it is a back-light you can shine a flashlight on the screen in a darkened room and you should see faint images. Use an external monitor to narrow it down to an inverter or perhaps a plug that had not been properly inserted (white one coming from the screen, center above the keyboard) If the external monitor does work then the problem most likely exists after that white connector if it has been inserted properly and has not been otherwise damaged during the repair process previously undertaken. Good Luck!
Jan 22, 2010 | Toshiba Satellite P35-S609 Notebook
Won't stay running
Update the Bios Driver for the computer off of toshibas website and it should fix it, I had the same exact problem!!! And if that doesnt solve the problem you have a bad battery...
Feel free to Email me with questions at newlook_inc@hotmail.com
hope this helps!! Good Luck
Jeremy
Sep 24, 2009 | Toshiba Satellite P35-S609 Notebook
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
P25-s609 display
When you say you turn it on, do any of the lights on the laptop light up? Does it make any beeps?
Have you done anything to your laptop or has anything happened that you think might have caused this?
Start off by simplifying your setup as much as possible to eliminate any outside influences.
Remove anything plugged into the laptop. Then unplug power and remove the battery. With battery out and power disconnected, hold down the power switch 15 seconds (this can clear out a corrupt BIOS).
Reconnect only AC power and try to power up. Verify your AC power has a power light lit up and all connections are snug.
If no go, try only with the battery and no AC.
Still no go, remove battery and any removable drive (CD, DVD, etc.). Connect AC power and retry boot.
If you feel comfortable removing the hard drive, remove it and retry boot.
If all drives are out, all external and internal devices removed and still no display, try removing the memory and putting it back in (reseating it).
Let me know if that helps or if you need further help.
Honest1abe
Dec 30, 2008 | Toshiba (K000006610) for Satellite P25...
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
