Question about Microsoft Xbox 360 Console
Cant get controller to sync with console
I cant get my controller to sync with the console the lights will run around the controller but no lights will come on the console no matter how long i hold the sync button
Press the sync butt0n 0n y0ur xb0x and c0ntr0ller at the same time
Posted on Sep 26, 2008
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Dec 16, 2014 | Microsoft Xbox 360 White Console
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
My xbox 360 wireless controller is new and the green light just keeps falshing it will not go on to 1 or 2 player.
you may have to sync your controller to your xbox. First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the sync button on the 360 controller so the lights around the big X are spinning around. you will find it located at the top of your control close tp LB (it has 3 little waves next to it) Finally, push the sync button on the 360( which is located directly to the right of memory unit B or with xbox360 s nex to the part at the front with 2 usb ports) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Wireless Controller
Blinken red light around the power button
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
Jul 26, 2010 | Microsoft Xbox 360 Console
My wireless controller just constantly blinks green around the outside of the center x circle. it doesnt stop at the top left of the x circle like it used to. what do i do?
If this is for your console:
*Solution* - It means your controller isn't synced with your console. At the top of your controller, there is a little sync button with waves next to it inbetween the two bumpers. Press that button once, then go to your console and press the similar button located on the front of it right next to Memory Slot B. You'll see the green light run circles around the main button for a second until they recognize each other, blink a couple of times and then you'll see the green light in the top left quadrant of the controller and the console.
If this is for the PC:
*Solution* - It could be in relation to a driver issue, power issue or both. First try unplugging any other USB devices you have to your machine besides the 360 controller. The wireless dongle used to connect to the controller uses a lot of onboard power. If unplugging everything but the controller get's the controller to sync, you might have to consider getting an upgraded power supply unit if you have a desktop or just getting a wired controller.
If that doesn't fix it, you can try uninstalling the current controller drivers you have on your system, downloading and installing the new drivers from Microsoft's web-site and try syncing again.
Jul 14, 2010 | Microsoft Xbox 360 Controller
My controller will not link with my xbox. it just flashes 4 green lights around the circle. what can i do?
Did you sync it? here's how to sync it:
Step 1: Power on your Xbox 360 console2_bing.gif. In this guide I'm assuming everyone already has their console2_bing.gif hooked up, if not, contact me.
Step 2: Power on Xbox2_bing.gif 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Step 3: Locate the small circular sync button on your controller. It is near where your controller can be plugged in (between the LB and RB).
Step 4: Locate the small circular sync button on your Xbox 360 console. It is next to Memory Unit slot 2.
Step 5: Press and hold the controller sync button until the green power lights start spinning.
Step 6: While your controller lights are still spinning press and hold the console sync button. The console's lights should spin also, then flash, and finally show the player slot light on both the console and the controller.
Viola! You've synced your wireless controller! You can sync up to four controllers.
Also, you can use this guide to sync to different Xbox 360 consoles. So you can bring only your controller to your friend's house.
Note: If you sync your controller to another console, you will have to re-sync it to your own afterwords.
Jan 23, 2010 | Microsoft Xbox 360 Controller
No Controller, No USB, No Quadrant
ok so its an internal problem with the system. if you have warranty findout if they will fix.
Apr 26, 2009 | Microsoft Xbox 360 Console
Wireless controller wil not sync with xbox 360
turn on the console. let it start up all the way. turn on the controller. on the console to the right side of the two memory card slots is a little button. press and hold it til the green lights start flashing around the power button. there is a little button on top of the controller. when the lights around the power button are flashing, press and hold the button on the top of the controller til the lights around the center button start flashing and then it should sync together
Feb 18, 2009 | Microsoft Xbox 360 Wireless Controller
How do I disconnect a controller from one xbox 360 and hook it to
press the synce button located on the front of the console. then press and hold the synce button on top the controller. the lights should tell you that the controller has been connected
Dec 01, 2008 | Microsoft Xbox 360 Console
Xbox controller
Try re-syncing the second (non-working) controller to the console. To do this turn both the controller and the 360 on, then find the little sync button on the 360 controller and hold it down until the lights flash in a clockwise circle. Now find the sync button on the 360 console and hold it down until the lights on the console spin in a clockwise fashion. Wait a couple seconds until the two sync up and then voila, you're good to go!
Here's pics of what the sync buttons look like:
Dec 27, 2007 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
