Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Loud noise I ran over a string and then shut it off quickly. It now makes a horrible grinding sound. Did I ruin the motor? Sounds like something came undone. I checked the belt and that is fine. Ideas?
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Posted on Oct 04, 2008
To start with, a vacuum belt is designed to be the weak link so that if the brushroll is stopped momentarily, the motor won't "burn up" or be permanently damaged.
If, on your Dyson, your drive belt is a cogged-tooth [or "Gilmore"] belt, I have seen instances of the brushroll becoming momentarily stopped, and the motor will then chew up a few teeth on the belt.
Running the vacuum anytime after this will/may produce a grinding noise.
If you examine your belt and see teeth missing, replace the belt (and they should be under $20 for sure) and that should repair such an issue.
Posted on Oct 09, 2008
My husband ran over my daughters shirt with our Dyson DC17 animal. Now it's making this horrible load ratting noise. I've taken the head off. Clean the beater bar. The belt is in tact. No
First make sure there are not any of the rubber cogs missing from the belt, it may be wise to replace the belt anyway because the cogs may be worn. Make sure the brush roll does not have any play in it anywhere and that It fits tightly in the nozzle housing without any play. If there is any play or wiggle that will cause it to move.
Apr 21, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Motor or beater bar making horrible noise
The belt could be damaged. Call the Dyson helpline. They will listen to the noise and troubleshoot it for you. If it is the brushbar motor they will have a repair dealer look at it. If it is the belt that is damaged, their solution will depend on whether your machine is still under warranty or not.
Jul 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Very loud operation
you have to remove the cover from the motor and check for debri it sounds like something is dragging against the fan which is built on the motor
Jul 07, 2008 | Eureka 2991AVZ Bagless Upright Cyclonic...
The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Jun 08, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Trouble with Dyson
Hi i had this problem myself and it sounds like your clutch assembly is broken which would be what the horrible noise your dyson is making only when your brushroll is on. Go to www.sparesaver.com to the help & support section.
It tells you all the information you need to know on how to Fit and take out your clutch and they supply it at a fantastic price!
Andrew
Mar 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
451 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
