Question about Mitsubishi Televison & Video
Please help!!!!!!!!!!!!!!! my mitsubishi vs-6015R television turns on for about 5 seconds and turns off right away.........what can I do???
  • mitsubishii Sep 26, 2008
    Thanks big irish
    for how long do i unplugg the tv for? Can you guide me to do this please I don't know what the crt pcb's is or any of the other stuff please help
    thank you
  • mitsubishii Sep 27, 2008
    thank you
  • 927 Answers
Good Day;
It sounds like you may problems in the TV's circuits, but try resetting first by unplugging TV from power source. If no fix try these areas of concern:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2.CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 LOCATED OFF PIN 1. (PCB-MAIN) D4000 PART #264P487030 3. CHECK PIN 8 OF IC401 FOR 27.7VDC. IF MISSING CHECK FOR OPEN D955 AND L961 AT S1 TERMINAL OF T902. (PCB-POWER) D955 PART #264P102040 L961 PART #411P012010 4. CHECK FOR DEFECTIVE IC401. IC401 PART #272P239040, OR INSTALL PT# IC-401, THIS KIT CONTAINS CAPACITOR C920, D4000 AND IC401. BE SURE TO MOUNT C920 ON FOIL SIDE OF PCB. 5. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT. Good Luck, big IRISH.
Posted on Sep 26, 2008
  • MICHAEL MULLINS Sep 27, 2008
    Good Day;
    I don't have the time to teach you 3-4 years of education and over 35 years experience in this forum, but to reset unplug for 2 to 5 minutes. I would recommend that you call an Authorized Service Center to come out and give you an estimate, the cost will run about (avg) $650.00.
Mitsubishi projection tv display does not turn on
unplug your tv for an hour and let it reset the cable didnot hurt your tv if that doesn't work check the tv's bulbs
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Need anwsers asap! Mitsubishi VS-60719 60 in
Can you psot a picture of what the lines look like and I will try and help you out with it. Please reply to this same post each time. Thanks
Aug 06, 2008 | Mitsubishi VS-60719 60" Rear Projection...
TV Code
you can get the actual remote for that model at www.replacementremotes.com just enter the model number. You may need the service manual to actually erase that code.
Apr 08, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Vs6015r
which model do you have the VS60603 or the VS6015R? Also try pushing in input and menu at the same time on the set and hold for 8 seconds to see if the tv flashes a code.
Mar 24, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-585R
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Dec 21, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-60719 60" Turns off
replace the regulator and check for bad connections
Sep 21, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
207 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
