Question about HP LightScribe dvd640i (DVD640I) DVD±RW Dual Layer Burner
I have a HP dvd/cd rewritable drive (external) - Model #dvd640e. I believe I have a dvd stuck in the drive, but I can't eject the dvd (I can't open the slot to place the DVD in the drive). I have unplugged the device from my PC, but I don't see how I can open it to remove the DVD (if that's what is causing the problem). I only see two small crews in the back, underneath the on/off switch. Any suggestions?
    Sergeant:
  • 264 Answers
Yes i have a suggestion for you. You will find a very small pin size hole just below the tray. You need to insert a needle/Pin into that hole and press it. The tray will come out and you will be able to remove the dvd.
Please rate the solution.
All the best
Posted on Nov 01, 2008
I have a Sony DVD/CD Rewritable drive that tries to eject but doesn't. It is model # DW-D22A. Is this a problem I might be able to fix or would I be better off getting a new drive?
It may have a jam, there is a small pin hole under the tray usually on the right side.. straighten out a paper click and press it in there with some force. This is the manual eject. See if it resumes normal operation after that.
Jun 28, 2011 | Sony DW-D22A DVD±RW Dual Layer Burner
You need to format the disk in drive H:before you can use it
Drive ID "H" is sometimes used as a spare partition for rescue disc purposes within Windows.
Mar 09, 2011 | Computers & Internet
I have a sony computer, the model where every thing is built in behind the screen. a CD is stuck inside and i cannot remove. anyone have any knowledge on what to do to remove same?
The CD, DVD or BD drive tray may not open when trying to eject a disc. This can occur if there is a mechanical failure, or if there is a disk stuck in the drive.
Please follow the following steps to resolve this issue:
  1. Because some applications can prevent the drive tray from opening, close all open applications.
    NOTE: If the Roxio DirectCD software is running, eject the CD using the Roxio DirectCD software.
  2. Attempt to eject the drive tray using the eject command of the operating system.
  3. Restart the computer to the BIOS by continuously tapping the F2 key on startup and, while in the computer BIOS, press the EJECT button on the computer.
    NOTE: If the drive tray ejects in BIOS, but not in the operating system, reinstall the CD, DVD drive.
Sep 16, 2010 | Sony VAIO VGC-RB40 PC Desktop
Can I put internal LG GH22 rewriter inside external GSA-E60N
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
Jul 22, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
HP dvd640e not recognizing DVD+R DL
6/25/9:  While this external HP DVD640e burner was listed as a NEW drive - "new" meant never used. A check with HP techs told me the unit was a 2005 factory closeout and the dual layer disc required for it is a 2.4 speed disc. I bought a 2.4 speed DL disc and it works perfect in it.  As far as seeing a CD when a DVD was installed is presumed also the fault of having the wrong speed disc in it (that lot of Memorex DL discs I am also having trouble with elsewhere too). Double-checking my profiler, it does give speed as 2.4x as the burner's profile. Alas, the problem was my newness to the DVD technology. A slap to the forehead and move on.
Jun 19, 2009 | HP dvd640e DVD±RW Dual Layer Burner
CD STUCK IN THE THE DVDRW DRIVER
Is it that the cd drawer will not open? If so-go to my computer and rightclick on the cd drive and select eject.
Jun 11, 2009 | Dell INSPIRON 6000 CENTRINO...
LG External Super Multi DVD Rewriter has frozen
there's a mini hole in front just put the needle or something like that and
push presto it will open try it!!!!!!!!!!!!!!!
Apr 27, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    HP LightScribe dvd640i (DVD640I) DVD±RW Dual Layer Burner Logo
    79 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
