Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
INK CARTRIDGES WILL NOT REGISTER AS NEW WILL NOT PRINT
I have rplaced my ink cartrideges and now when I go to print it still says they are empty. I have cleared the queue to the printer. I can scan and clean an calibrate. I have done all the suggestions. Turned off the computer reset the printer plugged and unplugged. Installed and unistalled. Still nothing. Pelase help!!!!!!!!!!!!!!!!
  • mfwalker Oct 10, 2008
    I have the same problem. I have been told that the printhead needs replacing, but I have only used two sets of ink cartriges since it was new. Will Kodak replace it for free.
    Problem Solver:
  • 12 Answers
If you can scan clean and calibrate, then your ink cartridge is not empty.
Posted on Oct 03, 2008
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Can i print documents using black ink only when other inks are empty?
All the ink cartridges need to have ink in them to allow you to print, even if you only want to print in black only.
Oct 14, 2012 | Epson Stylus CX8300 Printer
I have changed the empty ink cartridges but each time I try to print, it tells me that they are empty and to go to hp.com/recycle. Again, the ink cartridges are brand new. I was able to go to the...
Are you sure catridges are brand new? check any where ink is leaking? if its leaking try to arrest it or replace ink tube assm.Dont try to clean print heads every time it will consumes ink...
Sep 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
Lou
Oct 17, 2009 | Brother MFC-685cw InkJet Printer
Will not print black
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
105 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
