Question about RCA TruFlat 27F520T 27" TV
CURSED RCA I HAVE A RCA TRUFLAT 27F524T. WHEN I TRY TO TURN ON THE TV THE RED LIGHT BLINKS FOR SEVERAL SECONDS THEN FINALY THE PICTURE WILL COME ON. THEN AFTER A SECOND OR TWO THE TV WILL TURN OFF! ABOUT ONCE OUT OF ABOUT 5 TRIES IT WILL ACTUALLY STAY ON FOR A WHILE. ANY IDEA WHAT COULD BE CAUSING THIS? ANY WAY TO FIX IT MYSELF? THANKS
  • Lmart003 Sep 30, 2008
    My truflat tv's red light flash a few times and then it stops flashing but the picture won't come on. It only comes on after the 5th time or so. Any idea how to solve this problem?
  • 899 Answers
Its the EPROM chip and it is happening in thier other models as well. If you leave it unplugged for about a couple of weeks it will work for a while but will start again and it will get worse
Posted on Oct 07, 2008
Tv rca 27f524t flashea led no turn
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 18, 2014 | RCA TruFlat 27F520T 27" TV
How to unlock the tv with out a remote?
Hello
If you haven't a remote, it is very difficult to unlock the TV. Anyway try these following steps. Sometimes may help you.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Wish you sucess.
Oct 24, 2010 | RCA TruFlat 27F520T 27" TV
Need code for Innovage jumbo universal remote for a rca tv
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
RCA TruFlat Won't Turn On!
Same problem with Sony. Unplug for 36 hours at wall and it should work
Aug 11, 2009 | RCA TruFlat 27F520T 27" TV
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
RCA 27F524T Power comes on But no Picture
i want to know who wants to sell me their rca t.v?
Jan 21, 2009 | RCA 27F534T TV
Rca 52" problem
If you are saying the picture comes on red and then the tv turns off?
I would suspect the video ic on the red picture tube pc board has shorted out.
This is a pretty common problem
Apr 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sound
Try unpluging the power from the tv for a several seconds.
Jan 16, 2008 | RCA TruFlat 27F520T 27" TV
My RCA F32650 won't turn on and green power light just blinks.
yeah the blinks will tell u the culprit..basically cold solder,or bad vertical ic.but u need prof tech to help u fix that..hope this help..yhanks
Dec 25, 2007 | RCA TruFlat 27F520T 27" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
RCA TruFlat  27F520T 27" TV Logo
98 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
