Question about Gateway 2520915 Keyboard
Does not work nor does a new one
My PS2 keyboard Model SK9920 does not work. The 3 green lights don't even blink at all when the PC is turned on. I tried a brand new keyboard and it didn't work either.
The keyboard was unplugged yesterday with power off but ac power cord still plugged into back the of the tower. The PC will not work without the keyboard connected (the monitor & PC itself go into standby mode). I Also hear a clicking sound from time to time (like when PC goes into standby mode or when it's shutting down). Also on startup I get "keyboard not found" error message, only when my keyboard is connected, I can't use my PC at all if it's not. The keyboard is not listed at all in device manager (connected or not).
If there's no quick fix and I will have to resort to USB, can I just get an adapter to convert my keyboard to USB? I would like to keep this keyboard if possible, since it seems to be ok. Also if I gave you the model and/or serial numbers for this PC, would you be able to tell me if there are fuses behind my PS2 ports? Please help me if you can, thanks. By the way, I'm typing this with the PC utility keyboard.
  • lee5338980 Jan 01, 2009
    my pc logitech keyboard can not type anything after window started
Thank you for your response. I just went ahead and bought a USB keyboard and that solved my problem. Thank you once again.
Posted on Sep 26, 2008
I purchased an emachines a few years ago but continued to use the keyboard that I was familiar with. It is now worn. I have installed the new emachines keyboard and nothing happens...no lights come...
Did the old keyboard plug into a PS2 keyboard socket (round purple connector) or into a USB port (flat rectangular connector)? Similarly, what type of connector is the new keyboard?
If it is the round PS2 connector you may have connected into the green PS2 mouse socket instead of the purple keyboard socket. Although the sockets are similar, they work differently.
If it is USB, then try moving it to a different USB port.
Try the keyboard on another PC.
If you cannot get it to work then replacement keyboards are very cheap.
Feb 16, 2011 | E-Machines eMachines Desktop PC
PS2 KEYBOARD & MOUSE Not responding.
Try connecting one at a time, if you connect the mouse don't connect the keyboard, and if you connect the keyboard, don't connect the mouse, reboot each time and check which one is the culprit. One of the port or device must be creating the problem. Good luck.
May 24, 2010 | Asrock CONROE1333-DVI/H INTEL 945G CHIPSET...
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
I moved my computer and now my keyboard is locked. There is a light on the top right hand side of my keyboard that is highlighted green for locked. how do I unlock my dell keyboard
Is the keyboard usb or ps2? If its usb then try another port. If its ps2(Green) then power down the pc by holding in the power button for 8 to 10 seconds. Pull the plug and make sure no pins are bent. Plug it back in and boot back up. This should fix the problem if its ps2.
Oct 11, 2009 | Computers & Internet
No output on Monitor
Check if any of the pins of the Keyborad PS2 jack. Looks loke during cleaning a few vital parts may heve moved. Unseat the RAM sticks and after cleaning insert it firmly. Check all cable and wires for snug tight connections. You could try to clean ur power switch too bt aerasol spray, but the main is the keyboard. Recheck for bent pins and/or any stuck keys on the keyboard. If evrything is OK and the PC still behves the same, try replacing the power supply (SMPS) with a properly functional one & if it works, simply buy a new SMPS and install it....sodeep
Apr 13, 2009 | Intel Desktop Board D845GLLY Motherboard
Keyboard not working
Hi abcd_21;
Is that a usb keyboard or a PS2 keyboard? if its a PS2
kindly Do these steps below:
1. remove keyboard PS2 from PC
2. restart PC, and observe if you see the error "no keyboard detected"
3. turn the pc off
4. attach the PS2 kayboard then Turn ON.
if its a USB:
1. remove usb
2. restart pc
3. plug the usb in when the pc has completely booted up.
4. wait for the found new hardware icon to detect your usb
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
Ps2 light blinking
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!
Dec 24, 2007 | Sony PlayStation 2 (PS2) Console
Use with usb adaptor
If the USB to PS2 adapter has 2 PS2 ports, make sure it is in the correct one, but this should not be the problem. I have heard that some PS2 keyboards do not work with some USB to PS2 adapters.. Too much trouble to get a USB keyboard?
Aug 14, 2007 | ORtek SKB-2200 (skb2200) Keyboard
Gateway 2520915 Keyboard Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
