I have a Jensen JE1907DC TV in our new RV and it will not response to any commands...can not get to Menu, no picture, no sound....it turns on, but that's it! Can anyone help me with this problem.
ladywinn
  • 5138 Answers
SOURCE: TV COMES ON WITH REMOTE
Replace your batteries or try another remote controller.
Posted on Feb 17, 2009
ProMonkey
  • 59 Answers
SOURCE: colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Posted on Mar 10, 2009
  • 120 Answers
SOURCE: Have a Hitachi 55hdt79...no pictures only sounds.
It might be the power supply, check the main power supply. Audio power supply is seperate to main power supply, thats why you have a sound.
Posted on Jul 24, 2009
SOURCE: Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
Posted on Dec 20, 2009
  • 8457 Answers
SOURCE: Power on - Screen Black non responsive
U might get the tv working again,by unpluging it,replug an hour later let the tv reset it self.Not,Than the Tuner board,it the board u should looking into replacing.Not the power supply board is good,because u getting a solid power LED indicator light.
Posted on Apr 26, 2010
I have no sound on only one channel. How do I fix this?
Go to Menu,
Check balance.
Should be center '0'.
Otherwise it could be an electronic fault.
Blown speaker / loose wire / amp fault.
Oct 11, 2017 | Jensen Televison & Video
I have a jensen Je 1911 dvdc, it will not stay on but 8 seconds help we have 8 days left
Jensen 19" 12-Volt TV/DVD - Camping World
www.campingworld.com > ... > TVs & Accessories > TVs
Rating: 2 - ‎2 votes - ‎$269.00 - ‎In stock
Where does one get a replacement remote for the 19 inch /dvd model ??/. 1 answer(s)... Need remote replacement for Jensen JE1911ABC. 1 answer(s).
JENSEN LCD TV Accessories - Jensen RV Direct
www.jensenrvdirect.com > Products > LCD TVs
Items 1 - 12 of 22 - We also offer video control centers, PAL tuners, and digital tuner boxes which will convert your analog TV signal into a digital one.
postheadericon JENSEN JE1914DVDC DVD STAND
dynastre.tk/469748/dvd-jensen-je1914dvdc-stand
Dec 27, 2015 | Jensen Televison & Video
Having trouble connecting to analog TV in my RV.
is there an input setting in the main menu .to receive signals it has to be on antenna or air .then do an auto channel scan.try it without the convertor box .
Oct 04, 2015 | Televison & Video
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    On some stations I get picture but no sound. Sound works on all other stations. I have another tv and sound is fine on all of them. Any ideas?
    Try resetting the TV to the default settings (Menu > Setup (Options) > Memory Recall (Restore Default), select Yes and then Enter. Exit the menu to save.) Then rescan all channels. The Setup or Options menu icon looks like a wrench and hammer forming an X.
    My Viewsonic TV uses the commands in the parantheses but the current manual for the model gives new command names. The above commands worked to solve the problem for me. (In my case, one digital subchannel had video but no audio but the sister subchannel had audio but no video.)
    I hope this helps.
    Jul 09, 2010 | ViewSonic Televison & Video
    May 18, 2009 | Jensen Televison & Video
    Jensen TV in RV turns on by itself
    Hi
    Are you sure? the sleep menu is off? please double check your sleep menu!
    Thanks!
    Feb 25, 2009 | Jensen TS2750J TV
    Jensen TV
    Perhpas the TV has a timer function that is turning it on at a certain time. Does it seem to occuring at the same time of night? check the TV settings for a timer.
    The only other possibility is that the camper is losing AC power in the middle of the night, and when the power comes back on perhaps the TV is turning on.
    However, i rather suspect the first problem...
    I am a certified RV technician, so if you have other problems with your camper please let me know
    Sep 05, 2008 | Televison & Video
    TV cuts off while watching a show
    There are most likely some components in the power supply and or scan circuits that have become thermo sensitive.
    An experienced TV service man should be able to troubleshoot your set and fix it for you.
    Jerry G.
    Apr 19, 2008 | Jensen Q2749J 27" TV
    Televison & Video Logo
    169 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
