Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
We would be happy to help you with getting your DISH Network remote to control your TV. located on the top of your remote until all mode button back lights come on, then release. Use the number buttons to enter the codes foryour Curtis Mathis TV; here some of the codes we currently have: 516, 670, 219, 507, 674, 680, 708, 664, and 650. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Keep in mind that some codes may not be compatible with your equipment. If this is the case, please try the other codes listed for that device until you find one that is compatible with your equipment.
We hope this help and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
