Question about LG Washing Machines
I have an LG WF-T552A Washing machine it wont drain water from the spin cycle and the letters OE comes up on the screen
Your washing machine has a sediment trap in the bottom of it. if you take off the bottom plate you will see a cap/plug with hoses going into the back of it open the cap and clean it out. be ware lots of water will come out, i had the same problem and found 2 of my 1 year olds socks in it
Posted on Sep 26, 2008
My washing machine stops mid wash and on d LCD display it has the letters OE sometimes the machine doesn't spin an if t does the cycle it doesn't let the fabric conditioner go n the was
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. Clear the filter located on the bottom left on the face of the machine. You will find a access panel located there that you need to open. richroth_61.gif Happy Holidays The FixYa Team
Dec 19, 2010 | LG Washing Machines
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
NEC washing machine won't spin. Letters OE flashing
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Washing Machines
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
258 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
