My digital RCA tv is not running the full convergence program
  • 8,617 Answers
Whats the model number of your RCA. please respond to this post with your model number and also let me know if one color is out or are all 3 colors out of alignment.
Posted on Sep 26, 2008
My 52 inch RCA projection tv has a blue line around everything white
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
Feb 10, 2013 | RCA R52WM24 52" HDTV Projection Television
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Lost bulb convergence and all input except for digital
With TV turn off Press and hold Vol- and CH- at same time ,wait untill TV turns on then you should be in service menu adjust convergence,BUT if when TV is on and you Go to menu then setup and you do not see convergence listed in menu ,you have a blowed fuse FL231
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w27d no convergence in the set up menu cant run the convergence
some rca models have the convergence as a seperate button on the front or side of unit. sometimes if unit has guide plus+, unit wont have that option. try on your tv factory remote, with tv on, push menu, 7, 1, go back, tv. that is the code to reset your computer in tv.
Nov 14, 2009 | RCA Televison & Video
Looks 3d
Sounds like your Convergence needs to be adjusted. Go to your Setup Menu and look for Convergence. Choose that and the TV will automatically run it's Convergence program If that doesn't fix the issue then you may have to get the unit serviced
Sep 15, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD TV, convergence needs to be run and it is
You have a bad capacitor most likely on the convergance or other system board. You can purchase a manual and tester to find the fualty component.
Sep 13, 2009 | Televison & Video
RCA 56925 Projection TV
Good Day, enap;
With no control of the convergence on the TV, you more then likely have a Digital Convergence Power Supply Failure.
Cause: CR19710/CR19713 Diode Failure.
Part Number: New part with added reliability, 227066.
The board is a small one it is about 3" x 6", it's mounted in different places on the TV depending upon the exact/full model number, but it will be located on right side of the TV looking from the back.
Hope this will be helpful, Good Luck, big IRISH.
Jul 05, 2008 | RCA P52926 52" Rear Projection Television
Convergence power supply board
try www.partsstore.com they should have the board you need if its still available from RCA
May 25, 2008 | RCA TH1101 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
