Question about Dryers
Error code 68 frigidaire dryer
My dryer is beeping with an E68 error code I found the stuck button. how do un stick it. It is the ryness button
  • jomairaliz Feb 22, 2009
    My dryer is beeping with an E68 error code. How can I solve it?
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
  • 19396 Answers
SOURCE: frigidaire dryer giving E68 code
E68 means one of the buttons is stuck. Try pressing the buttons lightly, or disengaging them with a small tip.
Posted on Sep 14, 2008
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Posted on Apr 12, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
  • 8197 Answers
SOURCE: E68 error message
The code is for a stuck button on control panel. You will need to replace the control panel
Posted on May 16, 2010
What does code E68 mean?
Hello Erik;
My name is Peter. I am a retired field service appliance technician.
The code E68 appears when one of the buttons on the keypad is stuck in the down position. This is a common error with several different Frigidaire dryer models and tends to occur when the dryer is five or more years old. You may be able to un-stick the offending key manually. If not, you will need to replace the entire keypad.
Dec 08, 2014 | Frigidaire Dryers
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
May 18, 2014 | Electrolux Dryers
Frigidaire agq7000es0 gas dryer generates an e-68 error code. have cleaned the lint area. still get error message. the dryness button seems to have gone haywire.
This error code E68 indicates that a button or key is stuck. Press the buttons/keys repeatedly one at a time to possibly unstuck the key/s. It may also help you find out the stuck key/s as it will click differently from the good keys. You need to find and unstuck the key manually by accessing the control board if the error code still persists. Click on the link below for the detailed troubleshooting instructions of this error code.
Troubleshooting Error Code E68 on Electrolux/Frigidaire Dryers
Jun 18, 2011 | Dryers
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
Apr 06, 2011 | Dryers
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
What's error E68
E 68 One of the keys (buttons) is Enter function testmode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control
Jan 10, 2011 | Frigidaire Electric Dryer
E68 error message
May 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
The dryer gives E68 it starts running dor 30
the code 68 on the aeq7000es series is indicative of stuck buttons [your control buttons on the front]They sometimes stick in the closed position or go open [fail] and I have found the bad switch and replaced just the bad switch[ there should be a series of test to determine which switch button is bad] and if the switch buttons are testing good ,then it's control panel time. The control panels are about $150.00 on ebay ,sometimes you can find a "make offer" deal,but their few and far between.
Nov 18, 2009 | Frigidaire AEQ7000ES Dryer
Error Code E68 stuck button?
expensive it is....if you have them side by side I think you can do it and save lots
Aug 15, 2009 | Frigidaire AEQ7000ES Dryer
Dryers Logo
461 people viewed this question
Top Dryers Experts
