Question about Fuji Finepix S5800 Digital Camera
Stuck media card
I have a Fuji digital camera. I got a SanDisk ultra II memory card that incorporates a USB that foldsback when inserted into the camera. The first time that I put it in it refused to come out. It releases but "catches" and won't come out. The card still works as I can take and review pictures. It is a 2 gb card and I guess I could live with it like this but it limits the ease of making prints. The local photo repair wants $100 to fix it! Ever heard of this problem? Any suggestions? Thanks so much.
  • Anonymous Nov 13, 2008
    I have the same problem, I tried an 8Gb micro sd card in a Sandisk adaptor.
    I pops up to the point where you should be able to lift it clear, but then lock. it will let me take 4040 pictures but the camera now takes about 5 seconds to start up! I need this out and my 2gb card back in. I will post a solution if I find one!
Hi, I'm the guy that got the 8gb card stuck and the boot time of the camera went to about 5 seconds, (camera checking memory?) 5 seconds is not a lot to check 8gb of memory, but if you want to take a pic in a hurry it is a lifetime! - here is how I got it out.
Get hold of an RFID tag (security tag), the white strips that set the door alarm off at supermarkets. Luckily I had one on the packet of batteries I bought for my camera!
Cut it open and you will find two strips of really thin metal, you are going to use these as shims.
You need to make a 90 degree fold along the length of the shims about 2mm in from the edge.
(about the thickness of the card)
I held my shim in a pair of vernier calipers and ran the back of a knife down it to get my fold.
The thick part of the shim will go down the face of the card and the thin bit will go down the side.
I made 2 shims, one for the left and one for the right side of the card - I only needed the left to get the card out.
With the camera held with my knees and the lens facing away from my body, I pushed a shim down the face of the card (side nearest the lens) with the 2 mm bit running down the left side of the card where the locking notches are.
Slowly work it all the way down, pop the card up and down if you can - to help move the shim down.
Once it was down the whole length of the card, I popped the card up again, wiggled it a bit - and it came out! YES!
No more 5 second startup for me, with 2gb card in again - startup time was back to normal!
Good luck if you are try this:-)
Svjem77
Posted on Nov 13, 2008
I have the 8GB SDHC Card and when I insert it into my laptop it is not recognised. How do I change this?
may be the port does not support it , try inserting it to a card reader and plug the usb card reader to your laptop .
Jul 02, 2010 | SanDisk Ultra II 8GB Secure Digital High...
Card Cant Be Read
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
May 25, 2010 | SanDisk Ultra II 8GB Secure Digital High...
Sandisk Ultra 2 compact flash 8gb won't work in my camera (Olympus E-520), it says 'card full' & I am unable to format the card, it says 'card error'.
insert the card to a card reader then format it in the following way:-
right click my computer then menage then click disk menagement then right click on your card then click format. good luck.
Jan 09, 2010 | SanDisk Ultra II 8GB Secure Digital High...
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
PC does not recognize SanDisk Ultra II 8GB memory card.
install the usb drivers 3.0 it wi;l solve u r problem...........
Sep 27, 2009 | SanDisk 1GB microSD Memory Card
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
San disk ultra II won't show up on computer
You'll have to go to Sandisk.com to verify this for your specific model, but... the problem is that some firmware versions won't recognize over a 2GB card. There may be a firmware update available. Find your product on the site using search, and then look for software updates. Don't hesitate to call techsupport (866-726-3475).... usually NOT a long wait, they speak clearly and they're polite.
Feb 04, 2009 | SanDisk Ultra II 8GB Secure Digital High...
Can't initialize SanDisk Ultra II for S7000
try formatting it in the computer, then initializing it in the camera.
It's possible that the camera can only handle memory up to 1Gb. Try a 1g CF card.
Jan 01, 2009 | Sony Alpha DSLR-A200K Digital Camera
It looks as though the camera cannot support memory as high as 4GB. Capacities above 2.2 GB require that your camera supports "FAT32", and S7000 does not support FAT32.
Dec 30, 2008 | Fuji FinePix S7000 Digital Camera
Fuji Finepix S5800 Digital Camera Logo
63 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
