FRONT DOOR WHWEN SHUT DOES NOT CLICK. HENCE THE MACHINE DOES NOT START. CERTAIN CONTACT IS NOT ESTABLISHED.
Its prob your inner door catch or door striking plate the inner door catch has a bymetal strip inside that looks the door they wear out but if the striking plate is worn on the door it will also stop the inner catch to lock it is better to replaice both at the same time they are not to expensive to buy and easy to fit just turn off the power to machine unplug take the top off and you can get your hand dowm the front where the inner lock is undue the two screws which holds the inner door catch lift out and unplug the lock plug in new one and put back you will see how to replaice the outer door catch best to take the door off and lay flat
