Question about Toshiba e-STUDIO 50F Plain Paper Laser Fax
Toshiba fax #DP 125F
We have a prompt telling us we have a paper jam but do not see it anywhere. We need help because we cannot send a fax. We can receive them but not send them.
  • bkross Sep 26, 2008
    Yes, our old fax machine says it has a paper jam but we do not know where to fix it. We do not see paper stuck anywhere. Can you tell us where we should be looking??
Fax rec'd has large, fat, black marks all over the paper. Started out just a few, now whole page is convered. any ideas
Posted on Oct 06, 2009
    Genius:
  • 2,120 Answers
Open the top cover.
Remove the toner and drum cartridge. Where the paper comes out you'll see a cover for the fuser held by two screws. Remove the screws, pull straight up to remove that cover. The fuser is there.
Check the eject switch actuator. mounted on top of the fuser, it might be broken.
Posted on Sep 26, 2008
Toshiba DP 125F What do these status codes mean: a)NG B0 b)50 Also how do I fax to a long-distance number if adding long distance code?
If you mean by "50", Device Error 50, make sure the cable is firmly connected between the main motor and the Mother PBA (CN3), between the Mother PBA (CN24) and the Main PBA (CN12). Otherwise, replace in this order:
1. Main motor.
2. Main PBA
3. Mother PBA.
Jan 12, 2011 | Toshiba DP125F All-In-One Laser Printer
HP 1050 Fax Machine will not send out faxes. It sends the first page then prints out paper saying paper jam, but we have not paper jammed in the machine.
Sorry but still do not have it fixed...i printed off the manual for this fax but our problem is not on the trouble shooting list. But i'd think you would be able to tell how to fix it without charging for the sollution.
Oct 20, 2009 | HP 1050 Plain Paper Inkjet Fax
Paper jam
My dp85f, jams also.
The reason is, that the "fuser and pressure roller" unit is clamping an thus, the gearwheel driving this unit has been damaged.
Anyone knows, where to get spare parts?
Jun 05, 2009 | Toshiba DP-85F Fax
Saying paper jammed ..but no paper is jammed????
The course of the problem could well be when you pulled the paper the wrong way out ot clear the jam. Open the machine and have a close look at the unerside of the flap. There should be a micro switch, which could well be desloged.
George
Jun 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Paper jam message but there's no paper
There should be an exit sensor, as part of the fuser unit, I suspect it either has not been connected or is physacally jammed out of position. Check these areas, and also for pinched wires.
Hope this helps.
Ed
May 07, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Paper jam error
Check rear door for paper fragments check paper jam sensors ussally one front middle and rear make sure they arn't stuck, model make?
Oct 16, 2007 | Office Equipment & Supplies
"document jammed" but no paper in the machine
There are a few sensors in the paper path which can easilt dislodged when pulling paper to rapidly from unit. Check all sensor flags and make sure they are moving freely.
Jun 01, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Toshiba e-STUDIO 50F Plain Paper Laser Fax Logo
126 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
