Question about Canon imageRUNNER C3200 Color Printer
Canon c4080 can not print pdf files
At work, we have network printer c4080, everytime we print a pdf page or file, the printer can not handle.
All it printed out is a error page with few lines (can not remember the exact texts).
Please help.
  • 1,219 Answers
Do you have installed PS DRIVERs
Posted on Jan 13, 2010
We have a CANON IR C4080 and are coming across a little issue which could become quite annoying : Some Technical pdf come out with some blacken schematics, like the image is treated as a block (filled...
Hello thierry,
Wow, alot of variables here.If you are using PS drivers then you of coures MUST have a Fiery,or a Canon option that emulates PS.This can be as simple as it's onboard limited ability to emulate PS(which although is onboard is locked out unless you have prchased a special "license" to use it) or one of Canon's external print contollers that again "emulate" PS.This is a given,anything less than the 2 external controllers Canon offers (ImagePass H1/ColorPassGX100) will not provide full interpretaion of PS.And even the the high end controllers may misinterpret certain graphics data in the PS format as they are emulators of the Fiery controller.If you have niether of the 4 options (onboard licensed controller,H1,GX or Fiery) then you have inherent limitations.A simple PDF document would be better presented using the UFR II print driver available at Canon's website.Just as an Adobe PostScript document may not output properly using an inferior driver and/or controller,a PDF file may be ouput poorly using a PS driver.I hope I have been of some help to you as that's what I try to do,help. Best wishes and GFL ! :-)
Jan 14, 2011 | Canon imageRUNNER iR C4080 Color Copier
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
Colored ink is smearing on the page when I print
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
May 07, 2010 | Canon imageRUNNER iR C4080 Color Copier
Cannot duplex print pdf files. No problem for over 2 years until now. Word docs OK have tried changing printing settings and default but problem persists. Advice would be really appreciated. Thanks
Printing PDF files without special software can be a problem, if you print a lot of files of different formats and need to deal with a few printers.
Total PDF Printer from Coolutils is a program features a lot of printing modes and adjustable parameters that will help to optimize the process of printing PDF files. To save the paper, it offers ability to print PDF files in duplex mode, i.e. print PDF pages from both sides of paper sheet.
You do not need to turn each sheet by your hands, as the program changes printer settings so that this process is automated.
Total PDF Printer is a perfect suit for personal or professional use for printing PDF files. It automatically connects to all printers enabled in the system and redirects printing tasks to the trays you specify.
Print PDF Files In Duplex Vertical
Feb 07, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printer LCD says Cartridge Problem - Tri-Color. Refer to device documentation to troubleshoot.
Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print correctly may be damaged. See "Resolve problems printing a specific PDF file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's specific to the Acrobat product. However, the way Acrobat interacts with the system may affect printing performance. Go to step 3 to eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDF files. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the printer or the network correctly. Contact your network administrator or consult your network documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the original printer because of a communication, hardware, or memory problem. Make sure that the printer is turned on and connected properly, and then run a self-test on it to make sure that it's working correctly. For instructions, see the documentation that came with the printer. You may want to contact your network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==http://kb2.adobe.com/cps/316/316508.html
For more free tehnjical support you can visit-----http://tinyurl.com/lkrpwy
Jul 06, 2009 | HP Officejet J4680 InkJet Printer
Printing Acrobat 9 pdf file to the Imagerunner 7200
In acrobat go file, print and press advanced. Check print as image. Print the job again and see if you get different results. This does the image processing on the PC. Your document may have a postscript error in it and your device may be set not to print PS errors.
What driver language and version are you using?
Try updating your driver to the newest version, get device status.
You may also wish to try PCL printing for that file. (as a workaround)
Do other files have the same problem? What about when sent to another printer entirely?
Mar 05, 2009 | Canon imageRUNNER 7200 Copier
Canon imageRUNNER C3200 Color Printer Logo
236 people viewed this question
old marine
old marine
