Philips Magnavox 51MP392H Rear Projection Television Logo
DAISY PEREZ Posted on Sep 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have had this tv for about 3 years now. all of a sudden the bottom left hand corner has some red and green messing with whatever appears in that area and also the top portion of the screen all the way across does the same , also gives it a little blurr. its just the middle section of the screen that appears ok but still has a slight blurr. any idea what this can be or how it can be fixed?
Sonny Berry
Level 3:
  • Philips Master 8,617 Answers
  • Posted on Sep 26, 2008
Sonny Berry
Philips Master
Level 3:
Answers
8617
Questions
Helped
1721633
Points
23750
You will need to replace both STK392-120 Convergence ICs and you will also need four 6.8 ohm 1 watt resistors. You can get the replacement ICs and resistors at the following link with free instructions with pictures,
http://servicemanuals.vstore.ca/
2helpful
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Upper left corner is green
Check the mirror in the TV..may have come loose.
2helpful
DOUBLE PICTURE WITH DIFFERENT COLOR
this is a convergence problem,
well worth fixing
I would have a TV repairman take a look at it.
Regards,
daniel.
2answers
Green blured color started at bottom left corner and growing
Based off manufactureing timeline it sounds like you have some capicitors going bad you will need to contact a qualified Service agent for a service call to repair the problem.
Magnavox rear projectin television
Check the fuse first, if you are luck, probably you only need to change the fuse otherwise you probably need a new TV.
Turn off home electrity power or unplug all the expensive units when it is lighting to protect them.
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Picture problems
The convergence amps have most likely failed. This is the number one leading cause for the symptom your describing and the most common failure on that unit.
Your Tv take two STK392-120 Sanyo Ics for convergence amps, located at Ic7404 and Ic7405 on the board and mounted to a rather large aluminum heat sink. In addition you will most likely have to replace R3159 and R3160 (6.8 ohm 1w) resistors and test the remaining low ohm resistors for change in value.
A shop would really be earning their money on this particular unit if they charged $400 - $500 for the repair. It is an extremely difficult set to work on and there are a number of little problems that can reach-out and bite when attempting the repair.
Bill
Magnavox 51mp392h rear projection tv
The horizontal *forgot the name, want to say synchronizer, but i know thats not it* is going bad. Will cost about $400 to fix. Time to get a new TV.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
