Question about Toshiba 36A50 36" TV
Line across screen if i hite it it will work for a some time
Can you send me a print on what part to fix.
somebody told me it was noted for a bad solder connection
which I can fix if I know where it is
Thanks Chet
cmelius@nycap.rr.com
  • nogut15 Jan 16, 2009
    My 42" Toshiba has a thin colored line across the screen when I turn it on, it does have sound. After 10-15 minutes the screen starts widening and then it will be OK. But this happens everytime I turn it on.
    What is wrong and will it be expensive to fix it?
  • Anonymous Jan 20, 2009
    I have a 36 in toshiba it has a horizontal line when i hit the tv it will work for a while.
  • 4,234 Answers
If the line of which you speak is a horizontal line that looks like the picture collapsed, the problem is a vertical circuit problem. If hitting the set "fixes" it, then it is likely to be a bad solder connection. If you can solder, resolder the pins on the vertical IC. This is a small flat IC with about 11pins attached to a heat sink that may me marked LA7837 or something similar.
Let me know if that fails to resolve the problem.
Dan
Posted on Sep 26, 2008
Television only has one working line across the screen
Assuming that this is a CRT type TV, the problem is either bad solder connection at the vertical IC or a defective IC. If you could post the exact make and model of the set, I can provide a more detailed description of what needs to be done.
Thanks,
Dan
Jul 01, 2009 | iLO Televison & Video
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Line across the page
  1. Make a copy by using the platen mode and ADF.
  2. Send a print from your PC or print out the Counter list from User tools/counter button.
  3. Try printing one colour at a time - Black, Cyan, Yellow or Magenta.
If when printing, there is no line across the pages, so you need to clean the optics mirrors and exposure glass.
If the line appears in both 1 and 2 mentioned above, you have the fuser roller or drum damaged.
If the line appears in all colour prints, check the fuser or transfer belt.
If it happens only with one particular colour, check that drum unit.
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner DSc328 Copier
Red line across screen on a Sony kdf42e2000
OH YES, IS THE OPTICAL UNIT BLOCK BAD, THE PART # IS A-1212387-A
Nov 25, 2008 | Sony KDF-E55A20 55 in. LCD Television
My screen have some red lines
i had a similar problem with a 47 inch vizio lcd t.v. It would be fine for a while then all of a sudden the black areas and shadows would all become red lines in theses areas. I brought it back to the guy who i had purchased it from and he had told me that the reason for the lines was a bad video card.i got a new set and it works just fine.So i would reccomend getting a new card or sending it back to the manufacturer for them to install a new one for you. hope this helps.
Sep 18, 2008 | Samsung LTM1755 17 in. HD-Ready LCD...
Horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Good luck,
Ed
Nov 13, 2007 | Philips 27PT6441 27" TV
HP L7580 Printer Head Problem??
I had the same problem plus had problems with message indicating "alignment failed" and to monitor the blakc/yellow print head.  The print quality was very bad in black.  It seemed to print about 1.5 lines and then skip a line. When I replaced black and yellow it seemed to get better print quality was just as bad.  Finally called HP support. These are the steps they told me to do.
1. disconnect power
2. remove all ink cartridges
3. remove and clean contacts of both print heads
4. perform simultaneously the following press 6 and # on the keypad while at the same time plug in the power.
5.  --- the printer came on (black squares on the screen) and then shut off.
6. --- was told to power up the printer
7. Printer began checking device(took a long time)
8. Printer began aligning printer (took a long time)
9. Finally finished = Message on screen "Alignment Failed"
10. Still not printing and hours later.
11. They will be replacing printer
12. Then they hit you with that you should buy a set of inkjet cartidges from them at $109.96 -  warranty 2yr, works better, etc.
13. Sent to somebody else to arrange shipping new printer.
14. Free shipping 5-7 days - big deal -  placed my work (home office) on hold.
16.  Service help - listen when it follows the script, otherwise like talking to a door  (In India).
17. Finally get transfered to somebody else and he informs me that he is not authorize to give me a new printer, need to talk to somebody else who is not there.  Advises to call during business hours.  He said that he could request that I be called back but that it could take a 1.5 days to get back to me.
18. I am going to call tomorrow morning during business hours - wish me luck.
I don't know what is awaiting but IN The Future I will not talk to anybody from INDIA - they do not have authority and do not listen (but maybe they don't listen because they can't do anything about it).
Good Luck!!
Oct 03, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
Verticle lines following the color spectrum across the screen.
Had Sony KDF-E50A10 that had the same line problems after 16 months. Was fine at lunch time and when got home from work and turned it on, they were the lines. Want over $800 to fix it. Told me it was the B-Board assembly. Sony was no help. They have exteneded the warrenty on another part that works along with the B-Board but not just the B-Board itself, so probably not any more Sonys. I'm going with LCD now.
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Vertical lines across screen
first bad link !!! tell me if you get these lines away when you do little hits on the side of the tv , if so that mean you have bad soldering pin and need resoldering regards please don't forget to rate thx
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Toshiba 36A50 36" TV Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
