Question about Bose Lifestyle V20 System - black Theater System
Bose lifestyle v20 sound but no video
I have sound but no video
I got component cables to upgrade and hooked them up as so
Component cable from cable box to Bose
Component cable from dvd player to Bose
Component cables from Bose to back of TV
The sound works on everything ... cable, dvd, PS2 (which I don't have component cables for), but no video on anything. Is there something else I was supposed to connect to that I missed?
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Posted on Oct 01, 2008
Is it possible to connect an ipod to a Bose V20 via a minijack?
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
May 28, 2011 | Bose Lifestyle V20 System - black Theater...
No video at all!
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues, including HDCP (High Def Copy Protection) through HDMI issue. Component cabling should eliminate this problem.
I hope that helps.
___________________________________________
Download Bose LifeStyle V30 User Manual
May 31, 2010 | Bose Lifestyle V30 Home Theater System -...
I have installed the v30 bose lifestyle system but I can not get any video output on my Samsung led tv. I have tried the hdmi cable and the component cable. It both doesn't work.please help me with this
I recommend you stick with component cabling.
Having no picture at all generally suggests the V30 is trying a video mode your TV does not support:
  1. video type (PAL or NTSC)
  2. Progressive scan
  3. an HD resolution beyond your TV's range.
I hope that helps.
May 21, 2010 | Bose Lifestyle 30 System
Hi, I have an error 180 message in my bose lyfestyle V20
"Error 180" is either very bad (video board is defective) or just a temporary fluke and meaningless.. Best case-> the "error 180" could be fixed by a simple reset (unplug the DC power cable from the media center for about 30+ seconds). Worst case-> this will have to be sent to Bose for repair. Try re-seating any HDMI or component cables at the back panel as well. If you can see your system menu (by pressing 'system' on the remote) then the video board may be fine. If not, still reset it before determining anything else. Also, if the input device (DVD player) is connected with HDMI, and the output (the V20) is component.. this canl cause the error as well.
Jun 09, 2009 | Bose Lifestyle V20 System - black Theater...
Hello,I have a Bose Lifestyle
If you use both s-video and composite (yellow) video at the same time on the bose system, it thinks you want to use the component adapter (which is included with the system). Just use one or the other. But if this is still in black and white (it may because the system still thinks you're using the adapter) just press "system" on the bose remote, and go to "video" and then "video connector" If video connector says "Component", try to change this to "composite + s". If this doesn't let you change it (it may not) then restart the system by unplugging the DC power cable for 30 seconds and re-connect it. I hope this helps.
Jun 01, 2009 | Bose Lifestyle 48 System
Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Mar 15, 2009 | Bose Lifestyle V30 Home Theater System -...
Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Mar 01, 2009 | Bose Lifestyle V30 Home Theater System -...
How do I connect my iPod to Bose Lifestyle V20 System
and use either
Jan 04, 2009 | Bose Lifestyle V20 System - black Theater...
Cannot connect iPod to Bose Lifestyle V20 System
On the side of the V20 control box (with all the inputs/outputs on the back), there is a small jack for an input directly from the headphone output from your Ipod - so all you need is a male/male ended cord (like the one used in vehicles with AUX inputs) and plug in - SIMPLE!
ENjoy
Bose Lifestyle V20 System - black Theater System Logo
1,052 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
