Question about Kitchen Ranges
Kenmore gas range model number 75775891
Top buner does not light have clicking sound and gas, if I put open flame to it , it will light any sugestions PLEASE e-mail me @
parkertownfire@comcast.net
Thank You
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
bigg t
  • 640 Answers
SOURCE: Gas burners won't light
I would check the pilot orfices and the regulator on the unit.Seems like not enough gas pressure.Let me know
Posted on Dec 11, 2007
  • 28 Answers
SOURCE: kenmore range broiler burns orange not blue and leake gas
The only real important thing is blue flame with a orange tip,
also ranges have different nozzles for Natural Gas (NG) or propane(LPG)
he can check for leaks with soapy water at the flex line connection
Posted on Jan 05, 2009
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
I have a Kenmore gas range that doesn't light right away when I put the broiler on. I can smell the gas going to the pilot but it takes too long for the flame to light. Sometimes if I cancel the broil...
It seems to me that it is a bad thermocouple. It costs about $5. It senses the pilot flame and then tells the gas to turn on full. BUT if it uses an electric igniter that in itself is the gauge to tell the gas valve to turn on full. And that could be about $30 or more.
I am only slightly confused because you say gas range, but the broiler function is in the oven. So that is what I am believing what you are describing in your problem
Mar 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Sears Kenmore Gas oven lights and relights
sounds like dirty nozzle,or not enough air to make combustion, the poof sound is when it builds up with extra gas after flame quits,and re-lights there is a bit of excess gas around igniter.
clean nozzle.altho there is lots of safety percautions built in to stove,MAKE SURE LOTS OF FRESH AIR, AND STOVE AND GAS OFF,when cleaning nozzle.
[could be air intake problem to]
Dec 19, 2009 | Kitchen Ranges
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
May 27, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not come on.
If you have power to the ignitor but it doesn't come on then the ignitor is bad and will need to be replaced. Good job on checking for power to the ignitor first.
Nov 09, 2007 | Kitchen Ranges
Dec 22, 2006 | Kenmore 78673 Gas Kitchen Range
My range pilots work fine but my oven pilot will not light. Do pilots wear out after 4 years? Is it easy to replace a pilot?
Trey, this is not a hard fix. More than likley your ignitor for the oven has gone bad. It has to draw a certain amount of amps to open the gas valve. If you remove the bottom panel in the oven, should be 2 screws in the back and lift it out, you will see the flame spreader. Remove this, should be a couple 1/4 inch screws. Now you will be looking at the burner and ignitor. The part number for the ignitor is wb13k0021. The ignitor is held on to the burner with 2 1/4 inch screws. It is not uncommon for these ignitors to fail within 4 years....Catriver...post back.
Jul 29, 2006 | GE JGBS07PEAWW Gas Kitchen Range
Kitchen Ranges Logo
192 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
