Question about JBL (JBLRADIALWHT) Speaker System, Docking Station Adapter for Apple iPod
Compatability with 4th gen nano
When I docked my 4th gen nano, a message comes up that charging is not supported. I've always used the docking station to charge my 2nd gen nano & looked forward to doing the same with my new player. Have you any idea why this is occuring?
  • 1 more comment
  • mikebush4320 Nov 18, 2008
    When ipod plugged in 'charging is not supported by this accessory' appears on screen. How can this be fixed?
  • Anonymous Dec 26, 2008
    HELP!!!!!!!! the same is happening to me
    it is such a burdon to always have to plug my ipod into my computer to charge it when other people need to use it and get on there itunes
    somebody fix this problem soon!!!!!!
    thx
  • opiffle Dec 29, 2008
    Scosche has come out with an adaptor that works. This is their website: http://www.scosche.com/products/productI...
    I also saw it on the Apple's website as an iphone accessory.
Griffin also offers an adapter to remedy this concern. I haven't used it but here's a link.
http://www.griffintechnology.com/products/firewire-to-usb-converter
Posted on Sep 10, 2009
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
Posted on Dec 29, 2008
Im still waiting to see the stav 3300 manual that i asked to see before can it be produced or not
Try these they are fairly near. http://support.radioshack.com/support_audio/3151.htm
http://support.radioshack.com/support_audio/26922.htm
Otherwise you an contact us at ELECTREPAIRUSA@ELECTREPAIRUSA we repair/renovate and supply spares for all electronic and electrical equipment.
Jan 07, 2017 | The Audio Players & Recorders
Hi I have an apple ipod model A1285 I loaded music but i cant play it. The play list shows 0. Can you please assist.
may want to check the library in iTunes to make sure the files are there on your hard drive and on your iPod if the problem persists clear your library and make iTunes find your music in your hard drive again and try placing the music onto the device once more
Jan 06, 2017 | Apple A1285 Nano 8Gb 4Gen Personal Mp3...
The volume comes on loud even when i have turned it down before turning off
It sounds as if the UP VOLUME button/switch is broken and ON all the time. See if it is stuck down
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Aug 09, 2016 | Dual Audio Players & Recorders
Switch on akai58022 tower speaker, it worked when I got it today and now it wont even switch on
what do you have it plugged-into for power ? it uses the 8-pin Apple Lightning dock connector. If you are using a USB adapter for that, then be aware that a USB-port will only let you draw 500mA or 1/2 an Amp of power....more than that will cause failures and damage to the USB port and the Hub even.
Nov 13, 2014 | Audio Players & Recorders
I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on the amplifier. It mat be possible to have this end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Mar 24, 2014 | Audio Players & Recorders
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Mar 18, 2014 | Antec BXR-100 Gry Audio...
How to reset my combination lock number on ipod A1236
Hi William
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apr 03, 2013 | Audio Players & Recorders
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
I have a 1970's Panasonic Flip Clock Radio. (Model RC6530) The radio works just fine, but the flp clock stopped flipping. There is power going to the unit. I can also hear a low hum from the flip...
It looks like your problem might be an easy fix, at least. If the gear train between the motor and clock got stripped, you'd be in a bit more trouble. If the motor just isn't spinning, remove it from the side of the clock housing. There are 2 screws (or nuts) holding it in place. When you get it off, the cover for the motor will also be off. Apply some 3 in 1 oil, or perhaps just a tiny bit of penetrating oil, and give it a spin. From what I've read, it should do just fine. A lot of people use wd40, but I understand that can gum up over time.
This is a "at your own risk" type of repair, but as long as you unplug it before dismantling the radio, I think you'll be fine.
Feb 10, 2012 | Audio Players & Recorders
JBL (JBLRADIALWHT) Speaker System, Docking Station Adapter for Apple iPod Logo
1,393 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
