Question about Canon Cameras
I have the Canon Rebel XTi. I am getting a message the CF card has a problem. I am able to put card in computer and it opens the files that are on the card. The camera screen shows a blank space where the photo count should be. I have cleaned the connectors on the body of the camera and the lense. The camera is maybe 1 1/2 years old and I have taken maybe 10,000 photos. could the card need to be replaced? or could it be the camera itself :<(
  • maierw Dec 19, 2008
    How do you fix the problem??
  • 489 Answers
Look inside the CF reader at the pins... is there one or more that are bent or broken? This is most likely the problem.
If we need help with parts or the repair (every pin has to be soldered on individually) please let us know.
Good luck from Darntoothysam com
Posted on Sep 26, 2008
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
I have a CF err on my Canon Rebel XTI EOS
If your camera uses a compact flash card, then something is wrong with it. Possible causes: card needs formatting in camera (this will erase it) one or more pins inside camera are bent. Card was erased or formatted on computer instead of camera.
Feb 19, 2010 | Canon Rebel XTi / EOS 400D (body only)...
Problem with the CF card
Do both of these CF cards still function when you connect them to the computer?
Inspect the CF connector on the camera using a flashlight (torch). It's possible that one or more pins on the connector may have been damaged, somehow. If this is the case, the camera will need to be repaired.
Can you still operate the menus after the error message appears? If so, use the menus to reformat the card (see the manual for instructions).
Aug 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti digital camera mem. card will not lock into place
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
May 24, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CF Card
Please post back the error message you notice.
Mar 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CF Error
I had the same symptoms. I took it to an authorized Canon repair shop. For $150, they resoldered connections on my 'power supply board'.  No idea why the solder gave out. It's working great now.
Jul 09, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
