Question about Ovens
Control panel beeping & oven not working
Oven not working, and control panel beeps with a error code saying call your dealer. we have replaced the control board and still have the same problem . please help!!!!!
  • superscrips Oct 30, 2008
    I have a smeg single oven and all of a sudden it started beeping and saying the code... F4E0, The oven temperacture gage isn't coming on either???
  • Anonymous Jan 09, 2009
    I have a Maytag wall oven that is beeping F2.Help
  • 116 Answers
What brand oven, what is the model number, what is the error code seen. Try pressing the cancel button for about 10-15 second. Have you tried disconnecting power to the oven - do so about a minute
Regards
Posted on Sep 26, 2008
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Apr 21, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
Jan 19, 2014 | Thermador Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Ovens Logo
199 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
