Keypad issue. I would try disconnecting ribbon that connects keypad to main board. If that doesn’t solve problem after reconnecting ribbon, then keypad would most likely need replacing
E0 F2 is usually a stuck key on the keypad. You will need to replace your keypad most likely. It's possible to be caused by the control board also. If it is NLA we can rebuild it for you at fixyourboard.com
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
F2 - E0
Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
F2 - E0
F2 - E1
Keypad cable unplugged
F2 - E5
Cancel key drive line open
F2 - E6
