Question about Acer Aspire™ T180 PC Desktop
Hard Drive Why is my hard drive light flashing red!?!
    Sergeant:
  • 208 Answers
That little "red flashing light" on the front of your computer case is the HDD activity LED. When it flashes it indicates that there's hard drive activity. No, you do not need to worry about if flashing.
Thanx for using fixya,
Hope my info helps.
Posted on Sep 26, 2008
3 Suggested Answers
jhonRini
  • 32 Answers
SOURCE: hard drive does not boot
first u check wether ur hdd detect or not.u can check it from bios while booting press dell or f2 key (u can see on the screen which key have to use)to enter the bios and select stadard bios setup or disk drive specification on menu,if it detected u will see on the menu, again this problem remains may be the os prob.
Posted on Jul 02, 2008
mellomania
  • 121 Answers
SOURCE: Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Posted on Nov 13, 2007
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Xbox 360 3 flashing red lights
Well if they're flashing the hard drive is over heating and you need to get either a new hard drive or a new Xbox.
Feb 11, 2014 | Microsoft Xbox 360 Console
Red light on on my Buffalo HD
Red ERROR LED The way the unit gives diagnostic codes is by long and short flashes of the specific light. The number of long flashes give the first of two numbers and the number of short flashes give the second. For instance, one long flash and three short flashes would indicate an error of 13 -
E 00
(No light, beep only) - MPU error E 01 DRAM data line error E 02 DRAM address line error E 03 RTC chip error E 04 Flash rom error E 10 UPS power loss E 11 fan error (RPM too low or not functional) E 12 cooling error (unable to remove heat by the fan) E 15 disk error E 16 unable to locate internal HDD E 17 Unable to communicate with the RTC chip E 21 unable to communicate with the Phy chip E 22 mount error. The original Buffalo firmware has the following error messages based on the number of flashes:
3 Partition problem with hard drive. Reformat the hard drive. 4 Fan problem. 5 ROM problem. 6 Hard Drive can not be recognized. 7 Problem with motherboard (RAM, LAN, or Hard Drive controller). Exerted from http://buffalo.nas-central.org/wiki/Information/LSProLED
I hope this has been helpful, unfortunately without more information I cannot help any further.
Jul 20, 2011 | Buffalo Technology (USA), INC. - 500GB...
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
The flashing red light comes on with message E74 . What can i do?
It is because The hard drive is spoil if u remove the Hard drive and blow to the hard drive the red light will not come
May 17, 2009 | Microsoft Halo 3 for Xbox 360
Xbox 360 1 red light
Section
4 is flashing red Means
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
  • Turn the xbox 360 on, and wait till the 3 red lights are flashing.
  • Press and hold the sync up button (the small white one), while holding that button press the eject button.
  • The LEDs will now blink the first number in the code (as described below).
  • Release the eject button and press it again.
  • The LEDs will now blink the second number of the code.
  • The LEDs will now blink the third number of the code.
  • The LEDs will now blink the forth number of the code.
  • The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0022 GPU Error / GPU Overheating
0101 (not yet known)
0102 unknown error - literally means the console does not know what is wrong. Possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1030 (not yet known)
if your console comes up with ANY OF THESE CODES CALL MICROSOFT and they will repair anything for free
Dec 17, 2008 | Microsoft Xbox 360 Console
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Red and Blue flashing light
I have the same problem. I have a 500 GB hard drive and my computer will see the hard drive but it won't let me open it. It says "g:\is not accesible incorrect function" I have a lot of data in my hard drive and I don't have it backed up anywhere else so I really need to be able to be able to open the drive.
Jun 20, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Flashing Red Light
the drive is just connecting to your pc. now if it always stayed red, you'd have a problem.
Jun 06, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acer Aspire™ T180 PC Desktop Logo
480 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
